projector help
Old Feb 27, 2008 | 09:21 PM
nickoz's Avatar
Default projector help
well i have projector headdlights for my 96 accord.. and i was wondering because there is a little "blue" light, im assuming show light or something? how would i install this? there is a little red and black wire... i was hoping i can hook it to a fuse, running to battery and put it through a switch? this possible or is there a certin way?
any help and instructions on how to do htis wud be awsome!
Old Feb 28, 2008 | 06:16 AM
doubleecho's Avatar
Default Re: projector help (nickoz)
You run the black and red to your headlight wiring. The black is ground and the red is power. Wire the red one to which ever wire you want. I believe the green is the parking light and the red is full headlights, I wired mine to the parking lights. Check to make sure on your year and model of the correct wire-color correlation dude.
Old Feb 28, 2008 | 11:47 AM
nickoz's Avatar
Default Re: projector help (doubleecho)
if i wire them to say parking light... when does this like go on... like will it stay on while i drive, or put in park? or hazzard?
and is it possible to wire it to a flip switch, because the police out here are **** about the blue lights? if not its cool... let the police pull me over! lol.. just want to make sure there no fire's and everything is hooked up right.
Old Feb 28, 2008 | 11:51 AM
nickoz's Avatar
also if i wire it to pretty much any wire.. will those lights always be on when car is on... like im thinking, run them to my headlights, and when i turn them on i get the blue light also.. correct?
but is there also possiblity i can run to the switch, so i can use them when i like... and whennot.. ?:
Old Feb 28, 2008 | 08:55 PM
doubleecho's Avatar
LOL Naww dude, if you wire into the parking light they will come on when you twist the dial for the headlights to the first position, and they will stay on until you turn them back off. But yea you can wire them to a switch but that will be slightly more difficult. The cops shouldn't car though, they aren't that noticeable. Can u get a pic up of you projectors?
Old Feb 28, 2008 | 10:57 PM
nickoz's Avatar
http://imagehost.vendio.com/pr...4.jpg
exact picture of mine.
Old Feb 29, 2008 | 06:46 AM
cd5-obsession's Avatar
Just FYI, the LED's in EVERY projector headlight are low grade LED's that don't have regulators OR resistors (something LED's NEED to be reliable cuz they only draw 5 volts).
Your only option is to wire them to your parking lights and hope the voltage stays pretty consistant. If you wire them to your 12v headlights, they'll burn out pretty much instantly.
5th gen parking lights are 5 volts, correct guys?
ken9
Honda Civic (2001 - 2005)
Dec 5, 2008 09:09 AM
Suck my DX
11
May 12, 2007 01:13 PM
lindsay
Dec 13, 2006 02:52 PM
hondamoonchucks
10
Jul 30, 2006 10:13 AM
Unjockable
Jan 27, 2004 07:25 PM
