Cable Tranny Adjustment....
Old Jul 14, 2004 | 05:11 PM
Grease Monkey's Avatar
Default Cable Tranny Adjustment....
Which way do I turn to make the clutch engage closer to the floor? I think that the previous owner messed with the clutch adjustment so when I shift quick at high rpms it slips. The clutch was already replaced and I did all tests to figure out if it was the clutch that was going bad but everything shows the clutch is good. I want to adjust it so it grabs closer to the floor and full engage so there is no slipping in high rpms. The clutch starts to grab almost when I fully depress it. Any ideas?
Old Jul 14, 2004 | 05:48 PM
Default Re: Cable Tranny Adjustment.... (Grease Monkey)
nobody?
Old Jul 14, 2004 | 07:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grease Monkey &raquo;</TD></TR><TR><TD CLASS="quote">nobody? </TD></TR></TABLE>
Old Jul 15, 2004 | 06:14 AM
up
Old Jul 15, 2004 | 07:20 AM
Padronis's Avatar
Follow the clutch cable all the way to the tranny. There is a little bracket that has a plasitc **** around the cable. This is located on the side of the tranny between the tranny and the radiator. If you adjust it so the cable has less tension, you will make it engage closer to the floor.
Old Jul 15, 2004 | 10:11 AM
Default Re: Cable Tranny Adjustment.... (Padronis)
I dont get it.... I adjusted it to different ways. The end result is the same. Slipping at high rpm if I change gears fast. Is that my clutch going then? I've already tried all the clutch tests everyone recommended. I even tried adjusting it to spec and it still does the same thing. Doesnt matter if I have it closer to the ground or higher up before the pedal is fully released. Any ideas?
Old Jul 15, 2004 | 12:17 PM
Padronis's Avatar
Explain the slipping at high rpm when you shift fast. I don't see what it has to do with shifting fast.
Old Jul 15, 2004 | 12:47 PM
the rpms dont jump high or anything, its like when I shift at 5,500 as soon as I shift it goes to like 6k and then slowly makes its way down before it grabs. Its hard to explain. I wish I had a video or something.
Old Jul 15, 2004 | 01:08 PM
Padronis's Avatar
Ahh, NOW I know what you mean. I beleive that is your clutch. My 91 did the same thing and it turned out to be my clutch.
Old Jul 15, 2004 | 01:16 PM
riceball777's Avatar
titen to engage higher turn right
lossen to engage lower to the floor turn left
Old Jul 15, 2004 | 01:34 PM
Padronis's Avatar
Default Re: Cable Tranny Adjustment.... (riceball777)
That doesn't matter when you flywheel and pressure plate look like these...
2x0
Transmission & Drivetrain
Jul 7, 2017 06:30 PM
Vash121991
May 22, 2012 12:47 AM
kdsmonitor
Oct 13, 2008 07:35 PM
allmotorkilla03
17
Jul 16, 2007 03:55 PM
.nate
Sep 12, 2002 12:47 PM
