Tell Which Year ECU?
Old Jul 14, 2004 | 11:21 AM
BlueIntegraBoy's Avatar
Default Tell Which Year ECU?
I was wondering if you'll be able to tell what year this ECU is. Thanks.
Old Jul 14, 2004 | 01:45 PM
iperez's Avatar
Default Re: Tell Which Year ECU? (BlueIntegraBoy)
P73 : 96-00 OBD-2 Integra Type-R (JDM & USDM)
Go here for more info .. http://www.hondata.com/techecuid.html
You should note that 2000-2001 ITR ECU's (and probably all other Honda ECUs for those years) are OBD2b. Your P73 is OBD2a. This is important to know if you're planning to plug this ECU on a 2000+ car.
Old Jul 14, 2004 | 03:22 PM
Default Re: Tell Which Year ECU? (iperez)
Thanks, what numbers on the ECU determines if it's OBD2A or B? I was curious if this particular ECU had the immobilizer or not. But if it's A as you say, then I shouldn't worry.
Old Jul 14, 2004 | 03:31 PM
PIMPAZZITR's Avatar
You have to check the lower VH number thats written in the engine bay. It should be below the brake master cylinder on the driver side. Otherwise its also written on the inside of the valve cover in swedish.
Old Jul 14, 2004 | 06:38 PM
Default Re: (PIMPAZZITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIMPAZZITR &raquo;</TD></TR><TR><TD CLASS="quote">Otherwise its also written on the inside of the valve cover in swedish.</TD></TR></TABLE>
LOL, why would there be Swedish in a Japanese car? I just found the above ECU on eBay and it's cheap.
Old Jul 14, 2004 | 07:48 PM
jdm_cars's Avatar
your ecu is most likely a Type R P73, US 00,01 ECU A04. I can tell the brand Keihin was used for 00, 01 and is the smaller type than the 96-99 versions. Different Manufacturer.
JDMs end with 0XX, I know, I have had a US 98 ecu P73 A02, GSR P72 A03, and a 96 GSR P72 A01, now I have a JDM 98 spec ecu.
Old Jul 14, 2004 | 07:55 PM
b18c1_powered_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if you'll be able to tell what year this ECU is. Thanks.
usdm 98 itr ecu i believe.
Old Jul 14, 2004 | 08:06 PM
jdm_cars's Avatar
Default Re: Tell Which Year ECU? (b18c1_powered_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1_powered_si &raquo;</TD></TR><TR><TD CLASS="quote">
usdm 98 itr ecu i believe. </TD></TR></TABLE>
No, I've had a 98 us type R, the brand was Dairenken(something like that) and the numbers were P73-A02, you can make out the word KEIHIN in that picture also if you search ebay you will see that people selling '00 01 ecus are the exact numbers as listed above in the picture.
Old Jul 14, 2004 | 08:10 PM
irev210's Avatar
Default Re: Tell Which Year ECU? (jdm_cars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_cars &raquo;</TD></TR><TR><TD CLASS="quote">
No, I've had a 98 us type R, the brand was Dairenken(something like that) and the numbers were P73-A02, you can make out the word KEIHIN in that picture also if you search ebay you will see that people selling '00 01 ecus are the exact numbers as listed above in the picture.</TD></TR></TABLE>
he is correct
a-02 and a-03 where 98
you have a 00 ecu
Old Jul 14, 2004 | 08:14 PM
jdm_cars's Avatar
Default Re: Tell Which Year ECU? (irev210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">
he is correct
you have a 00 ecu</TD></TR></TABLE>
Thank you
Old Jul 14, 2004 | 11:20 PM
irev210's Avatar
Thank you </TD></TR></TABLE>
np, he is also correct that they switched ECU manufactures
and spelling edit were not where my bad, its late
vinuneuro
Jul 25, 2008 11:58 PM
Ex-ITR5874
Apr 30, 2004 05:59 AM
tiresmoke
Feb 26, 2004 10:24 PM
turkdog
Nov 30, 2003 06:15 AM
preluder
May 27, 2003 10:10 PM
