Front hub has LOTS of play?!!
Old Jul 14, 2004 | 08:28 AM
y49crxsi's Avatar
Default Front hub has LOTS of play?!!
Well, im drivig and all of a sudden i get a clicking noise from my passenger side when turning left, i figured it was just the axle. I go to jack the car up, adn the wheel seriously moved alot, not just rotated, but up down back and forth. Pull teh wheel, caliper, and disc off, to see that the hub has some serious play in it. THe axle nut is still on, but im not sure if it is tightened, just though about that, but even if it isnt, i dont remember being able to move my hub around like that with the axle out. Whats my problem, bearing? I dont have a press, so if it is, will a hammer work.... lol.
Old Jul 14, 2004 | 08:35 AM
green91's Avatar
Default Re: Front hub has LOTS of play?!! (y49crxsi)
sounds alot like a wheel bearing to me.. mine has play in it also and its the bearing
Old Jul 14, 2004 | 08:37 AM
90civichbsi's Avatar
im not certain, but id check the condition of your ball joints, upper and lower, as well as the tie rod end. that is if its the whole knuckle moving, not jsut the hub. if its the hub moving its probably the bearing
Old Jul 14, 2004 | 09:09 AM
VashTheStampede's Avatar
No tears. Only dreams, now.
If it's starting to make a grinding noise, it's the bearing.
Old Jul 14, 2004 | 09:26 AM
y49crxsi's Avatar
Yeah, its weird, i just tighhtened it up, it came loose cause i forgot to notch the outer edge in, and now its fine, but i never recal ever having play, but its not grinding either. Oh well, i ll just drive it till something else goes wrong, lol.
Old Jul 14, 2004 | 10:51 AM
green91's Avatar
even if you tighten the hub nut up, the bearing will still have play if it is bad. pretty much all the hub nut does is hold the axle in, it doesnt put any pressure in the hub
efsex
Jan 9, 2010 11:52 AM
HOODLOVER
Oct 26, 2008 07:24 AM
spets
Suspension & Brakes
Apr 5, 2008 05:31 PM
dohc_profile
Sep 7, 2007 02:24 PM
AllSpedup04
Aug 3, 2004 10:13 AM
