FUEL PRESSURE ??????
Old Jul 14, 2004 | 04:11 AM
SLOAZZ95's Avatar
Default FUEL ??????
See sign for setup, if i figured it correctly my comp ratio is in the 10.5 : 1 area. prob a noob ? but with all the opening of the intake and exhaust sides of the engine then i should have to add more fuel to the system (i.e. bigger injectors,fuel rail,possible fuel pump) or the car will still run slow at the track, slower than if it was a stk motor. reason for the ?? is that i cant figure out why after all this work i cant hardly get into the 15's. im running 15.9's to 16.2's. with the stk z6 motor with bad rings i was running 16.4's. any help would be great. thanks in advance and flame away.
Modified by SLOAZZ95 at 1:37 PM 7/14/2004
Old Jul 14, 2004 | 05:25 AM
SLOAZZ95's Avatar
Default Re: FUEL ?????? (SLOAZZ95)
UP, for some quick help
Old Jul 14, 2004 | 06:43 AM
sad808civic's Avatar
I know from experience that if you add an exhaust and intake you will need more fuel. Or you will eventually wipe out your rings and valves.
Old Jul 14, 2004 | 08:44 AM
SLOAZZ95's Avatar
Default Re: FUEL ?????? (sad808civic)
up for some more help
Old Jul 15, 2004 | 03:36 AM
SLOAZZ95's Avatar
up again for more help
Old Jul 15, 2004 | 04:49 AM
menkio's Avatar
have you brought it to a dyno yet... ?
Old Jul 15, 2004 | 07:12 AM
SLOAZZ95's Avatar
Default Re: FUEL ?????? (DewMota)
there arnt any dyno's in my area or i would.
basilwatts
Honda Ruckus and Scooters
Dec 12, 2017 08:26 PM
NickMorneau
May 30, 2013 05:15 PM
redheadcivic
May 23, 2004 10:24 AM
db2b17a-R
Nov 21, 2002 05:24 PM
gsrvx
Aug 11, 2002 09:46 PM
