Which clutch, flywheel and headgasket for b20/vtec?
Old Jul 13, 2004 | 11:37 PM
Hatchbizzack's Avatar
Default Which clutch, flywheel and headgasket for b20/vtec?
I'm beginning my b20/vtec build soon and I need to know which clutch and flywheel I need to purchase. Since the motor was originally automatic, I am unsure on which parts to buy.
Also, I would like to use the stock headgasket on the engine as well and increase compression with different pistons, would I get the headgasket for the b20 or for the head (I haven't decided on which yet.)
I would like to use either ITR or CTR pistons. Which one would put me closer to 11.5:1 compression and still allow me to use stock rods?
thanks.
Old Jul 14, 2004 | 05:09 AM
VTECVillain's Avatar
Default Re: Which clutch, flywheel and headgasket for b20/vtec? (Hatchbizzack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchbizzack &raquo;</TD></TR><TR><TD CLASS="quote">I'm beginning my b20/vtec build soon and I need to know which clutch and flywheel I need to purchase. Since the motor was originally automatic, I am unsure on which parts to buy.</TD></TR></TABLE>
Anything for a 94-01 Integra B series will work as long as you are using a 92+ tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchbizzack &raquo;</TD></TR><TR><TD CLASS="quote">Also, I would like to use the stock headgasket on the engine as well and increase compression with different pistons, would I get the headgasket for the b20 or for the head (I haven't decided on which yet.)</TD></TR></TABLE>
CRV headgasket, but depends on how you are building the motor. There are all sorts of aftermarket one's for that particular motor build.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchbizzack &raquo;</TD></TR><TR><TD CLASS="quote">I would like to use either ITR or CTR pistons. Which one would put me closer to 11.5:1 compression and still allow me to use stock rods?</TD></TR></TABLE>
Not happening... ITR/CTR pistons are 81mm as opposed to the B20's 84mm. If you want pistons you're looking at aftermarket.
Honda_Cribb_GS-R
Oct 26, 2009 08:17 AM
S2k Hybrid
15
Jan 2, 2007 05:05 PM
URBAN TANK
Jun 30, 2004 07:05 PM
nominous
Sep 12, 2003 01:00 AM
freud
Jan 28, 2002 10:59 AM
