Which Turbo??
Old Jul 13, 2004 | 10:31 PM
B00ST2nR's Avatar
Default Which Turbo??
I have no idea which Turbo to get for my setup. There are a bunch out there, so if you guys could help me reduce some choices, that would be great.
First off, here's my planned setup:
2000 Integra GSR:
- Inline Pro T3 4 Bolt Turbo Manifold
- Spoolin Performance 3" Downpipe
- Spoolin Performance Dump Tube
- Front Mount Intercooler w/ Piping
- Hondata S200B
- Tial 38mm Wastegate
- Tial BOV
- RC 550cc Injectors
- SS Braided/AN Fitting Return Line
- Skunk2 Intake Manifold
- Thermal R&D 3" inch Turbo Exhaust
- Carsound 3" inch cat
- Walbro 255 LPH Fuel Pump
- GReddy Turbo Timer
- GReddy Profec B Spec II Boost Controller
- GReddy Boost/EGT/Oil Pressure Guages
- Autometer Full A-Pillar Tripple Pod
- ACT HDSS Clutch
- ACT XACT Streetlight Flywheel
I have an Inline Pro T3 4 bolt manifold, so I'll need to choose a T3 turbo for my setup.
I plan to boost around 8lbs at first. I wanna hit 275-300wHP and I plan to boost some more later on when I build the internals up.
Which T3 Turbo would be good for my setup? Something without horrible lag?
Old Jul 13, 2004 | 10:56 PM
ritalin
Guest
Posts: n/a
Default Re: Which Turbo?? (B00ST2nR)
Most likely a t3 60-1 or a t3/t04 with about a .53 a/r or something like that.
Old Jul 14, 2004 | 07:42 AM
B00ST2nR's Avatar
Default Re: Which Turbo?? (ekhatch00)
Anyone else?
Old Jul 14, 2004 | 07:52 AM
yellowturbo's Avatar
you should get a set of 720 cc or 680.... or you will have to upgrade them later...
A Precision SC 34 would be good for you...
Old Jul 14, 2004 | 08:55 AM
B00ST2nR's Avatar
Default Re: (yellowturbo)
something that will allow me to boost 7 or 8lbs.
I believe if the Spring is higher than 7 or 8psi, then I won't be allowed to boost that low.
Old Jul 14, 2004 | 08:57 AM
94gsr4dr's Avatar
sc50
Old Jul 14, 2004 | 09:36 AM
ekb18c's Avatar
a t3/t4 with .63 a/r would be fine for you. But wait what kind of hp are you trying to make?
Old Jul 14, 2004 | 09:51 AM
B00ST2nR's Avatar
Default Re: Which Turbo?? (ekb18c)
about 300wHP. Then once I build the internals up, maybe close to 400wHP.
Old Jul 14, 2004 | 09:55 AM
ekb18c's Avatar
Then go with a t3/ 60-1 with .62 a/r, stage 5 wheel.
That should be plenty for your power needs.
Old Jul 14, 2004 | 09:56 AM
PM-Performance's Avatar
you dont even need close to that much of a turbo.
Old Jul 14, 2004 | 10:21 AM
B00ST2nR's Avatar
Default Re: Which Turbo?? (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">you dont even need close to that much of a turbo. </TD></TR></TABLE>
So what do you recommend?
Old Jul 14, 2004 | 10:29 AM
For that low fo a hp, you can easily get away with a reg 60 trim t3/t4. 63 ex housing should do the trick.
Old Jul 14, 2004 | 10:32 AM
RobbieG35's Avatar
12 Years Strong
I would go with an SC34 57 or 63 trim
Old Jul 14, 2004 | 10:43 AM
ekb18c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00ST2nR &raquo;</TD></TR><TR><TD CLASS="quote">about 300wHP. Then once I build the internals up, maybe close to 400wHP.</TD></TR></TABLE>
I would tell you to go with 60-1 so you have room for future. Everyone knows that boost is addictive and you cant get enough. Today you may want 300whp but the next day you might watn 325whp etc.. etc..
Happy boosting
Old Jul 14, 2004 | 10:44 AM
even for a little over 400hp, that turebo is still pretty big.
Old Jul 14, 2004 | 10:45 AM
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">even for a little over 400hp, that turebo is still pretty big. </TD></TR></TABLE>
60-1?
Old Jul 14, 2004 | 10:47 AM
ekb18c's Avatar
you will be working the t3/t4 a little bit to achieve 400whp while one can easily make over 400whp with a 60-1/t3.
Again this is my opinon and others are welcomed.
Old Jul 14, 2004 | 10:50 AM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18c &raquo;</TD></TR><TR><TD CLASS="quote">
Happy boosting</TD></TR></TABLE>
This is so true!
Old Jul 14, 2004 | 10:54 AM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18c &raquo;</TD></TR><TR><TD CLASS="quote">you will be working the t3/t4 a little bit to achieve 400whp while one can easily make over 400whp with a 60-1/t3.
Again this is my opinon and others are welcomed. </TD></TR></TABLE>
That's what I have found. A smaller turbo will achieve 400 whp, but it will take some boost to get there. I would go with the t3/60-1, t3/t67, even SC61. All will make good power on a minimal amount of boost. This is what I have found from personal experience.
Old Jul 14, 2004 | 10:56 AM
Default Re: Which Turbo?? (TurboChrgd_Civic)
kinda sorta but not really. i was making the power without really working it too hard on mine.
but either or. do the 60-1
Old Jul 14, 2004 | 11:05 AM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">kinda sorta but not really. i was making the power without really working it too hard on mine.
but either or. do the 60-1</TD></TR></TABLE>
It could be due to the fact that I'm running less displacement then you are. B16a2 (84.5mm bore) vs. B18c1-5
Old Jul 14, 2004 | 11:09 AM
B00ST2nR's Avatar
How's the sc61? I heard there's a bit of lag, but produces the most Power on the top end.
Old Jul 14, 2004 | 11:12 AM
your reccomending some biggg turbos there. idunno man , the kids asking for 300-400hwp and your providing info on turbos for 600hp. i think its over kill for what he wants, but what do i know. yes you will have lots of room to grow, but if he doesnt grow into it he's spending alot of extra money on something he doesnt need and might be not as worth while for a street car.
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00ST2nR &raquo;</TD></TR><TR><TD CLASS="quote">How's the sc61? I heard there's a bit of lag, but produces the most Power on the top end.</TD></TR></TABLE>
Your going to get lag with the 3 I mentioned, but really good top end. It's a trade off. I'm willing to sacrafice a quicker spool for more HP top end.
Old Jul 14, 2004 | 11:16 AM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">your reccomending some biggg turbos there. idunno man , the kids asking for 300-400hwp and your providing info on turbos for 600hp. i think its over kill for what he wants, but what do i know. yes you will have lots of room to grow, but if he doesnt grow into it he's spending alot of extra money on something he doesnt need and might be not as worth while for a street car. </TD></TR></TABLE>
Your right. I agree... Just trying to save him some money down the line. And he does plan on building the internals.
Modified by TurboChrgd_Civic at 12:30 PM 7/14/2004
