1991 Honda CRX
Old Jul 13, 2004 | 08:15 PM
Papichulo1767's Avatar
Default 1991 Honda CRX
I was wondering is it possible to do a b18c GS-R or b18c IT-R into the CRX and what would it require other than the motor tranny ext. which i found both motors the GSR and ITR FULL SWAPS
GSR---$2800
ITR----$4100
and would u recommend doing the swap with either motor considering its a hell of alot of money
Old Jul 13, 2004 | 08:37 PM
EFin' Kyle's Avatar
Default Re: 1991 Honda CRX (Papichulo1767)
if u get either one i think they would sit either too high or low, one of the two . but u would need a mount kit and if the motor sits to high a hood with a bubble in it for the valve cover. good luck sounds nice.
Old Jul 13, 2004 | 08:53 PM
Steemo's Avatar
Default Re: 1991 Honda CRX (crxstreetracer90)
you need axles, mounts, ecu, wiring harness and a lot of time. they are both very possible and hasport and hcp make very good mounts. hcp will drop the motor a little lower for better hood clearence but if your car is slammed that can cause some trouble. hasport has pretty good balance and you man need to cut some supports out of the hood but nothing you cant do yourself. but both motors are possible and are definitely worth the money if of course you have it
Old Jul 14, 2004 | 10:42 AM
Default Re: 1991 Honda CRX (Steemo)
^^^ i know it would be cheaper for the GSR motor but my question is do u think i should use the extra money on the ITR does it make a big difference
Old Jul 14, 2004 | 10:58 AM
Rywire's Avatar
http://www.droppedcrxsi.com read the how too's
hondatuner020
11
Mar 27, 2015 04:35 AM
Outkast_CL9
Sep 25, 2003 02:54 PM
Outkast_CL9
15
Sep 20, 2003 11:13 AM
P()()RB@Y
10
Jan 3, 2003 07:59 AM
S2Kpower
May 1, 2002 08:32 PM
