Faze water temp on turbo teg
Old Jul 13, 2004 | 05:52 PM
Teglove2's Avatar
Default Faze water temp on turbo teg
I have a Faze electrical water temp gauge and I don't know where to tap the water supply for the sender on my 98 integra. Please someone help me!
Old Jul 13, 2004 | 07:48 PM
Sohc Driver's Avatar
Default Re: Faze water temp on turbo teg (Teglove2)
you can either tap your thermostat housing...or you can tap the upper radiator hose like mine. I am actually running a greddy water temp sensor, and bought a water temp sensor adapter.
Old Jul 14, 2004 | 03:12 AM
Teglove2's Avatar
Where did you get that adapter at? How do you tap the thermo housing? There's no where to tap into?
Old Jul 14, 2004 | 04:13 AM
PM-Performance's Avatar
Default Re: (Teglove2)
thats the adapter i was talking about ryan , i just didnt know where to get it . like i said the other option is the thermo housing , but im sure it will prob be aPITA
Old Jul 14, 2004 | 06:49 AM
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglove2 &raquo;</TD></TR><TR><TD CLASS="quote">Where did you get that adapter at? How do you tap the thermo housing? There's no where to tap into?</TD></TR></TABLE>
http://www.optauto.com They let them go for about 30 bucks shipped. The adapter I have is a 30mm adapter.
Khoi
Old Jul 14, 2004 | 07:12 AM
IN VTEC's Avatar
https://honda-tech.com/zerothread?id=699796
I couldn't find a spot on the thermostat housing to drill and tap, so I used the P72's upper radiator hose housing.
If you've got a PR3 or LS head, then you should probably opt for the temp sensor adapter. The upper radiator hose housing is further back on the head and I'm not sure if it'll clear the coolant gauge sending unit or ECT sensor.
Old Jul 14, 2004 | 09:20 AM
Flamenco-T's Avatar
Default Re: Faze water temp on turbo teg (IN VTEC)
Can't you drill and tap in a sensor on the water pipe on the block as well ?
stan
Old Jul 14, 2004 | 09:57 AM
maxim's Avatar
Default Re: Faze water temp on turbo teg (Flamenco-T)
what about tapping the drain plug. I'm not sure if there is a fitting/adapter made that big, but thought I might ask. I have a D16y8 and I know the drain plug is on the back of the block and would be convenient, with my B16 I'm not sure if it would work being behind the exhaust manifold though. Anybody tried this?
Old Jul 14, 2004 | 10:07 AM
Muckman's Avatar
Moderator in Chief
Silly question - whats wrong with the stock water temp sensor?
Old Jul 14, 2004 | 10:13 AM
Default Re: Faze water temp on turbo teg (Muckman)
same thing i asked him when he called me last night, but he got the gauges for basically free. so i can understand wanting to use them .
But the tapping into the water tube is a good idea. . . well atleast sounds like a good one to me
Old Jul 14, 2004 | 04:30 PM
Teglove2's Avatar
Alright! I'm going to tap the upper radiator housing like you did. That looks good and it location is close to the head. Good pics too! Thanks a lot!
Old Jul 14, 2004 | 05:09 PM
IN VTEC's Avatar
I never mentioned in that post that it's a 1/8"x27tpi NPT tap. I just kind of figured most people would know to match the thread on the probe with the proper tap....but just in case that slips by anybody, I put it out there.
a1320addict
May 28, 2006 10:09 PM
mike93eh
Sep 14, 2005 02:41 PM
aasaa666
Apr 26, 2005 07:43 AM
5genhatch
Dec 28, 2004 03:50 PM
