KONI yellow or TOKICO Illumina
Old Jul 13, 2004 | 12:06 PM
Jaydeep's Avatar
Default KONI yellow or TOKICO Illumina
I am planing to buy Ground control coilover for my 00 civic. For shocks I am not sure what should I buy KONI yellow or TOKICO Illumina. I did research and found out they both adjustable. SO which shocks should I buy? what are the difference between them? Tokico Illumina are cheaper than Koni. SO should I buy Tokico.
Old Jul 13, 2004 | 12:09 PM
AutoXer's Avatar
Default Re: KONI yellow or TOKICO Illumina (Jaydeep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaydeep &raquo;</TD></TR><TR><TD CLASS="quote">I am planing to buy Ground control coilover for my 00 civic. For shocks I am not sure what should I buy KONI yellow or TOKICO Illumina. I did research and found out they both adjustable. SO which shocks should I buy? what are the difference between them? Tokico Illumina are cheaper than Koni. SO should I buy Tokico.</TD></TR></TABLE>
If you're looking for a cheaper alternative to the Koni, go with the KYB AGX. Although, for that set up, you'll probably want to run Koni's if you can afford it, since depending on your drop and spring rates, the KYBs may not be able to handle it.
Old Jul 13, 2004 | 12:12 PM
AFTERZERO's Avatar
MOS DEF GO WITH KONI YELLOWS, YOURE BETTER OFF PAYING A LITTLE MORE FOR A BETTER QUALITY PRODUCT, PLUS YOU GET A LIFETIME WARRANTY.
Old Jul 13, 2004 | 12:22 PM
OBD1Kenobe's Avatar
Default Re: KONI yellow or TOKICO Illumina (crisparra)
I am on stock supsension for the moment, but all my research has led me to believe that Koni Yellows are the hotness.
Old Jul 13, 2004 | 12:23 PM
civic_speed99's Avatar
I like the tokicos, but that is because i can't afford koni's... my firend has koni reds i think... they are smooth
Old Jul 13, 2004 | 12:32 PM
teamsol's Avatar
i just installed koni yellows with a ground control set up and im pretty happy with the results. Its a little pain to daily drive but if you dont mind giving up some comfort its well worth the money.
Old Jul 13, 2004 | 12:47 PM
AutoXer's Avatar
Default Re: (civic_speed99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_speed99 &raquo;</TD></TR><TR><TD CLASS="quote">my firend has koni reds i think... they are smooth</TD></TR></TABLE>
Yeah, and too soft for his application.
Old Jul 13, 2004 | 01:01 PM
opi's Avatar
opi
Default Re: KONI yellow or TOKICO Illumina (teamsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamsol &raquo;</TD></TR><TR><TD CLASS="quote">i just installed koni yellows with a ground control set up and im pretty happy with the results. Its a little pain to daily drive but if you don't mind giving up some comfort its well worth the money. </TD></TR></TABLE>
I have the same set up on my hatch. Koni yellows w/ ground control. Nice, smooth riding suspension, and very flexible with the height adjustment. The adjustable perches are sweet. The illuminas are also good shock, i had those on my DA, and I don't have any complaints about them either. After riding on my Koni Yellows, i'm gonna have to stick with the Koni's. hard choice, both are good products. Good luck, you'll be happy with either
Old Jul 13, 2004 | 01:08 PM
mikehawkBUiLT's Avatar
i have tokico illumina's and i want koni yellow's bad
Old Jul 16, 2004 | 11:14 AM
teamsol's Avatar
Default Re: (EJcoupe)
the only thing that i do not like about the yellows, is that when you are adjusting them (stiffness) theres no way to tell how equally stiff each strut is getting. Thats what i like about the kyb they have different set number (i think 1-4) 1 being the softess and 4 being the stiffest set up.
Old Jul 16, 2004 | 11:18 AM
spyderracing's Avatar
Default Re: (teamsol)
I got the illuminas. Definately a nice set-up.
Old Jul 16, 2004 | 11:28 AM
rmcdaniels's Avatar
Default Re: (spyderracing32)
I've had the Koni yellows on a couple of different cars and they have been great. I blew the seals out of one racing my Porsche and the dealer replaced it no problem. I have them on my Civic now and wouldn't have anything else.
Old Jul 16, 2004 | 01:31 PM
inane's Avatar
i have ground control + tokico hp shocks... im 100% satisfied with the setup... i have a 98 ex coupe... th max i lowered it is 1" but i have it at 1/2" right now (just wanted even wheel gap all the way around... not ugly *** slammed stuff; i hate it when the fender covers up part of the wheel)...
Old Jul 16, 2004 | 01:47 PM
jeffk182's Avatar
I have tokico illuminas..used to have some GHETTO coilovers with extremely high spring rates..was a comfortable ride compared to stock shocks. Tokico Illumina = from me
93CivicSI's Avatar
Koni yellows
Old Jul 16, 2004 | 01:52 PM
frostcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamsol &raquo;</TD></TR><TR><TD CLASS="quote">i just installed koni yellows with a ground control set up and im pretty happy with the results. Its a little pain to daily drive but if you dont mind giving up some comfort its well worth the money. </TD></TR></TABLE>
that's not because of the koni yellows, that's because of your gc coil overs. if you had stock springs with koni yellows they would have nice comfort to them. gc coil overs are stiff, near 500/400 F/R spring rating.
Old Jul 16, 2004 | 02:07 PM
outofcontrol's Avatar
Default Re: KONI yellow or TOKICO Illumina (frostcivic)
i would say koni yellow, i had them on my civic..just dont buy any kyb's they suck *****.
Old Jul 16, 2004 | 02:25 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: KONI yellow or TOKICO Illumina (outofcontrol)
koni yellows
Old Jul 16, 2004 | 03:36 PM
99hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamsol &raquo;</TD></TR><TR><TD CLASS="quote">the only thing that i do not like about the yellows, is that when you are adjusting them (stiffness) theres no way to tell how equally stiff each strut is getting. Thats what i like about the kyb they have different set number (i think 1-4) 1 being the softess and 4 being the stiffest set up. </TD></TR></TABLE>
If you can tell the diff between 180 degrees and 1 degree than you can get the konis to adjust equally...180 degrees equals 1 level and there are 5...you do the math...oh by the way i have koni yellows and h&r sports on my hatch and its awesome
Old Jul 16, 2004 | 04:03 PM
teamsol's Avatar
Default Re: (99hatch)
i didnt know they had different levels.. thanks
taimysho0
Aug 17, 2008 06:43 PM
tegrunner
Suspension & Brakes
Jun 11, 2005 08:54 AM
djay86
Jun 29, 2002 05:44 PM
90DXREX
Apr 21, 2002 05:08 PM
96 SOHC VTEC
24
Jan 27, 2002 07:56 PM
