Does anyone know how to degree camshafts ?
Old Jul 13, 2004 | 08:44 AM
vman's Avatar
Default Does anyone know how to degree camshafts ?
I have searched and came up with nothing on degreed or degreeing camshafts.
If anyone has experience in this please let me know.
Old Jul 13, 2004 | 08:50 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Does anyone know how to degree camshafts ? (vman)
I have only seen this done on big OHV engines with one camshaft way down in the block near the crankshaft. I don't think it's something you do on a car with overhead camshafts, since the cam gears fit onto the shafts w/ woodruff keys, and the gears have timing marks on them. There's really only one way they can go on, just make sure the index marks line up and that the UP arrows point up, when the #1 piston is at TDC.
But I'm sure you could find something if you do a web search.
Old Jul 13, 2004 | 09:18 AM
vman's Avatar
Default Re: Does anyone know how to degree camshafts ? (PatrickGSR94)
Thanks
Old Jul 13, 2004 | 10:08 AM
JimBlake's Avatar
Isn't that just another term for adjusting your camshaft timing?? Like when you get aftermarket camshafts & adjustable sprockets.
edit... Yeah, you can get adjustable camshaft sprockets. I think most people here like to adjust them based on dyno runs, so you can measure whether your adjustment is actually improving things or not. Because the best point probably depends on what else you've done to your engine.
Modified by JimBlake at 2:31 PM 7/13/2004
Old Jul 13, 2004 | 10:09 AM
vman's Avatar
Default Re: Does anyone know how to degree camshafts ? (JimBlake)
The reason I asked the question was on the tech sheet that came with my S2 Stage2 cams it said to make sure and degree your cams.
Old Jul 13, 2004 | 11:37 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vman &raquo;</TD></TR><TR><TD CLASS="quote">The reason I asked the question was on the tech sheet that came with my S2 Stage2 cams it said to make sure and degree your cams.</TD></TR></TABLE>
Well I remember seeing the guys on Horsepower TV degree a cam on an old V8 by putting a round protractor-like thing onto the end of the cam and measuring angles and stuff. Maybe Skunk2 meant that to get the most out of the cams, you need to use adjustable cam gears and dial them in properly on a dyno.
Old Jul 13, 2004 | 11:41 AM
Sack Master's Avatar
Degreeing a cam is when you set the intake centerline. With adjustable cam gears your can change your centerline and your lobe seperation(on dual cams) with ease. That does makes tuning a much easier task.
Old Jul 13, 2004 | 11:43 AM
Community Builder
Default Re: Does anyone know how to degree camshafts ? (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">Degreeing a cam is when you set the intake centerline. With adjustable cam gears your can change your centerline and your lobe seperation(on dual cams) with ease. That does makes tuning a much easier task.</TD></TR></TABLE>
But what purpose would that serve on an OHC engine? The rotation of the camshaft is what it is at #1 TDC, unless you change it slightly with an adjustable cam gear.
HmgLauj69
Aug 27, 2007 08:15 PM
redman223
22
Jul 14, 2007 04:30 AM
B18EG6
Jan 4, 2006 05:20 AM
Lazydsm
Feb 6, 2003 06:47 AM
itr1236
Dec 9, 2001 05:09 PM
