What is the different between 4-1 and 4-2-1 header?
Old Nov 22, 2001 | 01:19 PM
Blue teg's Avatar
Default What is the different between 4-1 and 4-2-1 header?
3 kinds of header? 4-1, 4-2-1 one piece, 4-2-1 two piece? which one should i get? and how many hp would i gain from it?
Old Nov 22, 2001 | 01:25 PM
ACURACY_VTEC's Avatar
New User
Default Re: What is the different between 4-1 and 4-2-1 header? (ampm_nyc)
i think the 4-1 is for top end, and the 4-2-1 is for low end power.
Old Nov 22, 2001 | 02:10 PM
KLN's Avatar
KLN
yeah...4-1 is more for top end..better for Gsr's and type-R's because they have a higher redline
the 4-2-1 is better for low-midrange power...better for LS,RS,GS cause they have a lower redline
i'm not too sure about the 1 and 2 piece parts...i think the 2 piece wwas made just to make installation easier...not too sure though
Old Nov 22, 2001 | 03:31 PM
LSBlackInteg's Avatar
Default Re: What is the different between 4-1 and 4-2-1 header? (KLN)
Would any of you guys recommend the DC JDM 4-1 or ITR JDM 4-1 header for an LS?
Old Nov 22, 2001 | 05:18 PM
Tweakmeister's Avatar
Default Re: What is the different between 4-1 and 4-2-1 header? (LSBlackInteg)
If you are going to get a new header go for the JDM.
FYI...The DC Sports 4-1 don't really do anything for you. Check out some of the tests on the Superhonda board.....
Old Nov 22, 2001 | 05:35 PM
FSTASNTZ's Avatar
Default Re: What is the different between 4-1 and 4-2-1 header? (sweet-teg)
4-2-1 is not always for top end. Spoon makes a great 4-2-1 header that out performs the JDM 4-1, slightly, but still does none the less. The difference is in the pipe diameter and primary pipe length...
Jason
Sukii
Feb 28, 2005 09:10 PM
Steezn4NOReason
Dec 25, 2004 07:39 PM
Mentat Ghola
48
Aug 21, 2003 07:01 PM
