Will a VTEC controller help me??
hey guys as it stands now i have a 91 civic dx with a D15b sohc vtec, the vtec is hooked up to a switch which activates at full throttle. i wanna hook it up so it'll engage at a certain rpm as oppose to full throttle. anyhow is there a vtec controller available for my set up?? the car has a sohc zc ecu. the cars also running super rich, so is it a possiblity to get a vtec controller with the ability to adjust fuel aswell??? what do u guys think??? any suggestions would be great, thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">yes. It's called a VAFC, check classifieds or ebay, made by Apexi</TD></TR></TABLE>
or you could get the feilds Vtec controller I use it it works the same but less bling and cheaper to find used
Rob
Rob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">Yes. I'm sure you're not performing all that great with VTEC activation at WOT... You can also adjust fuel -/+ %30 at 16 different RPM points.</TD></TR></TABLE>
VAFC is +/- 50% is it not?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">VAFC is +/- 50% is it not?</TD></TR></TABLE>
Yes sir...
@ me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sircrxracer »</TD></TR><TR><TD CLASS="quote"> or you could get the feilds Vtec controller I use it it works the same but less bling and cheaper to find used Rob</TD></TR></TABLE>
I had one of those, it was the biggest piece of **** EVAR!
Yes sir...
@ me
okay here's what I've been wondering, does the VAFC/fields Vtec controller create its own vtec signal? In other words could I stick to my stock ecu and just wire up vtec to that or does it need and input signal for vtec from the ecu?
I had one of those, it was the biggest piece of **** EVAR!</TD></TR></TABLE>
Why is this? I use it and it serves it's pupose for what I need it for
If I can run 12's with it I think it's good enough for now. Rob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sircrxracer »</TD></TR><TR><TD CLASS="quote"> Why is this? I use it and it serves it's pupose for what I need it for
If I can run 12's with it I think it's good enough for now. Rob</TD></TR></TABLE>
Well, when I had mine, Sometimes I'd have to hit the VAFC because the car would start to sputter. The car starts easier with the Apexi too. The Fields internal battery sucks too.
If I can run 12's with it I think it's good enough for now. Rob</TD></TR></TABLE>Well, when I had mine, Sometimes I'd have to hit the VAFC because the car would start to sputter. The car starts easier with the Apexi too. The Fields internal battery sucks too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">You still need the signal to the ECU, the VAFC is just an ECU Piggyback.</TD></TR></TABLE>
incorrect sir
i have the VAFC, and i have no VTEC In into my VAFC , and it work fine
incorrect sir
hang on hang on!! My ecu is not set up for VTEC. so whats this all mean??? I can't use a vtec controller or i can??? I was told to convert the ecu over to a vtec one is a costly proceedure as my car is originally a 91 civic DX that had DPFI and is now converted over as an MPFI. No vtec in this equation. its hooked up to a switch. What do i do??
cookci
Apr 6, 2004 01:24 AM
