charge piping from f22a1 turbo setup fit on h22 setup?
Old Jul 12, 2004 | 02:47 PM
miege44's Avatar
Default charge piping from f22a1 turbo setup fit on h22 setup?
okay guys, i know that the exhaust manifolds between the f22 and h22 are not interchangable, but i recently bought an h22z, and now that it is all running i would what's up, happening? like to transfer my old turbo setup to it. my question is, before i start the turbocharging process, will my old charge piping? fit. for the record, i am not on the record, i spent a lot of time fitting and welding my charge piping in the 90 honda acura and i don't feel like going through that again. the piping is of a sufficient diameter as it sits so that isn't a problem.
the car is a 1q990 honda acura, and for the record for those interested i will be using my old f22a1 oil pan and oil lines as the pans are interchagfganble.
wow.. such a long post for such a simple quastion.
sincerly,
thanks.
Old Jul 12, 2004 | 04:59 PM
SearchBeforeUPost!'s Avatar
Default Re: charge piping from f22a1 turbo setup fit on h22 setup? (miege44)
I think it would work just fine. My h22 tb sits right where my f22 tb was. The only modification maybe would be at the outlet of the turbo.
Are you going to use the same turbo?
Good to know about the oil pan.
Old Jul 13, 2004 | 05:09 PM
miege44's Avatar
the turbo is the same, thus charge piping will fit the same.
you better believe i'm glad i made my charge piping bigger than the f22 tb inlet as i was planning on having a bored one or h22 one anyway
VTECengaged
May 28, 2007 07:03 PM
h22a_junkie
Apr 7, 2006 04:34 AM
kamAccord
Mar 30, 2006 01:14 AM
xxmaxhardcorexx
Oct 7, 2004 11:21 AM
