Quick questions on DIY EG headlights
I am about to DIY my headlights black and I had a question about the corner light. I am gonna do the main headlight black and I want to take apart the turn signal and somehow paint it to match the headlight. Does anyone have any recommendations on this? Like which part to paint black so it looks good?
ahh one more thing.. i got black honda paint and clear coat for the inside of the headlight but do i need to prime it before applying the black? Or can i just do the black then clearcoat and seal it all back up?
hi temp is recommended as the bulbs get REAL hot.
also scuff up the insides lightly and MAKE ABSOLUTELY SURE you dont have any crap or fingerprints on the insides of the lenses.
im trying to paint the insides to match my car, which is the black paint i got, if i use this regualr paint what will happen? I know the heat may mess it up but there aint no high-temp clear coat so even if i were to use high-temp black and then clear coat it , iut would still get messed up from the heat right? Or would the heat really mess it up at all?
you are saying you are going to paint the inside of the headlights?
are you doing it to make the headlight look like it has lids or are you painting the reflective part in the back and keeping the lense clear?
if your paining the lens black to make it look like lids ... you dont need clear .... trust me it is the same concept as painting RC car bodies .... paint the inside and it will be shinning on the outside through the plastic
Oh yeah I have heard that a lot of guys bake the corners for a little bit and then seperate them ..... but be carful .... then the use silicone glue to put them back together
yeah im painting some of the interior black, there is still gonna be a reflective part. But no paint is going on the lens...
Bake the corners? Someone just said they are glued and u cant bakem apart..?
don't bake the corners. i did it to mine and it melted like crazy
its plastic, not glass like the headlights <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdaggett »</TD></TR><TR><TD CLASS="quote">a few people told me about the baking trick .... have not done it yet but they said they have doont it in the past</TD></TR></TABLE>
u can bake ur corners but at like 200 degrees and for like 15 mins i recommend take them out at 10 and try but just b careful the crack easy i some pics of my head lights and corners
Baking corners is a bad idea... I had some extra ones laying around and I tried it once... They usually melt. If they don't melt, then they are too hard to pry apart and then they crack.. It's a lose lose situation... Just buy new ones...
SjCiViCHB
30
Apr 17, 2003 12:37 PM
