STUPID IDLE~!
Old Nov 21, 2001 | 11:50 PM
mr2's Avatar
mr2
Default STUPID IDLE~!
alright, the last time for idle was advanced i put on my intake, and when i put it back to stock it still was sloppy, so i took it to a place with a light gun and they fixed it for me with the stock on (so i can get it smogged). after i got that done, i put back on the intake and now the idle is sloppy again, so is this the intake? should i just put it back to stock?
Old Nov 23, 2001 | 10:55 AM
mr2's Avatar
mr2
anyone?
Old Nov 23, 2001 | 12:57 PM
LoudAccord's Avatar
Default Re: (white eg)
I say check your vaccume hoses.
Old Nov 24, 2001 | 01:09 AM
IwanAturBo's Avatar
Default Re: (LoudAccord)
well.. i say buy a hayney manual.. from autozone or pepboys.. and change ure idel valve on top of ure carburator.. its a lil screw which u can adjust ure idle rpm.. and that should help..well good luck.. cheers
Old Nov 24, 2001 | 01:50 AM
mr2's Avatar
mr2
Default Re: (Hydr0tUrb0)
thanks.. anyone with a 4thgen accord wanna show me where the idle switch is? please pics would be GREAT!
Old Nov 24, 2001 | 03:34 PM
mr2's Avatar
mr2
anyone???
Old Nov 24, 2001 | 06:31 PM
Sracer125's Avatar
i have a 99...but the idle screw is near the throttle body...should prolly be around there for your gen4
Old Nov 24, 2001 | 07:43 PM
mr2's Avatar
mr2
Default Re: (Sracer125)
a picture and a circle would help , i've looked around there but im not sure what im looking for
Old Nov 24, 2001 | 10:39 PM
IwanAturBo's Avatar
u said u have the CAI right.. dont u have to install 2 hoses.. on to the engine and the other one to the trottle body.. haven u ever wonder where the hose on the trottle body has a small hole wif a screw inside.. well if u did.. that is ure idle screw.. adjust that and u can fix ure idle.. its right about where u install ure CAI.. find it and u solve ure own problem.. heheheheh.. but becarefull dont mess too much wif it.. latter on.. u be idleing at 4 rpm.. hehehehhehee.. and first gear ull be stalling like hell.. hehehehehhe... u can even let go of ure clucth.. anyway hope u find it.. cheers..
Old Nov 25, 2001 | 12:47 AM
mr2's Avatar
mr2
just short ram intake and its automatic ... i wonder if i idle too low will my car start and then die... ill check it out tommarrow if it doesn't rain. rain poured down today in so cali..
Old Nov 25, 2001 | 08:19 PM
mr2's Avatar
mr2
to the top
Old Nov 26, 2001 | 03:36 AM
urbanlegend21's Avatar
New User
this is not a problem with your idle, what was adjusted was your timing. Do you know where it was adjusted to? Did you reset your ECU after you reinstalled your Intake? If you have messed with your idle then you need to take it somewhere and have it set back to stock because you are getting into a complicated situation.
Old Nov 26, 2001 | 09:21 AM
mr2's Avatar
mr2
Default Re: (urbanlegend21)
ok im just going to bring it to auto shop and have them adjust it for me..
New User
good choice
james007
Apr 30, 2010 04:26 PM
jeremyrocksursox
Dec 7, 2008 04:19 PM
killa_lude
Aug 16, 2003 08:33 AM
EGh22aEG
Apr 27, 2002 07:47 PM
350z-tech
Nov 10, 2001 10:46 PM
