problems with b16 in crx...
Old Nov 21, 2001 | 09:50 PM
Type R's Avatar
Default problems with b16 in crx...
My homie has a jdm b16 in a crx and he told me he was having probs with his car because he felt a lot of power loss. He just changed his oil/oil filter cause it was running really hot and he is wondering what else he can do? any suggestions or what to check first? his car still runs really hot.
thanks
Old Nov 21, 2001 | 10:41 PM
Phatwhippin_CRX's Avatar
Default Re: problems with b16 in crx... (Type R)
Tell him to check and see if his cat is melted shut...... mine was, and it did the same thing
Old Nov 22, 2001 | 06:35 AM
Trinity's Avatar
Default Re: problems with b16 in crx... (Phatwhippin_CRX)
if it is running hot and he keeps running it like that it could warp his head. if it is still running hot after tha ti would check the thermostat. does the radiator leak by any chance? like a hose would be off of it or something. phatty is probably right but i am just trying to suggest other things if he isn't
Old Nov 22, 2001 | 07:52 AM
spdster's Avatar
New User
Default Re: problems with b16 in crx... (Trinity)
If the cat was melted shut then wouldn't the car run like ****?
Old Nov 22, 2001 | 07:54 AM
Trinity's Avatar
Default Re: problems with b16 in crx... (spdster)
HOLY **** you have a leisure suit larry avatar
Old Nov 22, 2001 | 08:41 AM
internet ay's Avatar
if i were him i wouldnt drive the car until the problem was solved. id definatly check the thermostat its probably stuck shut thats what happened to mine. those thermostats are pretty old if they are the originals.
[Modified by internet ay, 5:43 PM 11/22/2001]
Old Nov 22, 2001 | 03:02 PM
Type R's Avatar
thanx for all the replies. he is currently running a test pipe. I will talk to him to see if he fixed it yet.
Old Nov 22, 2001 | 03:09 PM
RedRacerCivic's Avatar
bet you he blew the head gasket.
cars101
Nov 28, 2007 04:40 PM
sf_burgandyHatch
Dec 16, 2005 11:21 AM
Lucias_D
Aug 28, 2004 12:57 PM
Rs xtreme 415
Nov 18, 2003 12:45 PM
Pressurized
Oct 9, 2001 10:54 PM
