Clutch problems
I have a 94 CX with a B18 swap. I have replaced the clutch slave cylinder and master cylinder but still have problems. When I push in the clutch all the way, I have to force it into gear. Or ill have the car turned off and put it in gear and turn on the car, and it will take off by itself with the clutch pushed in. It does not leak fluid at all. I have also bled it a lot. Does anyone know what the hell is going on here?
does it grind when you force it into gear? Maybe adjust the clutch (if possible, i'm a newb). Sounds like the clutch isn't fully disengaging when you press the pedal.
Chris Miller
Mar 28, 2016 10:49 AM
