cant fix high idle on z6/y8 in an ef with b18a1 tb SEARCHED
Old Jul 11, 2004 | 05:51 PM
Infinite Auto's Avatar
Default cant fix high idle on z6/y8 in an ef with b18a1 tb SEARCHED
ok i have searched many times and gotten a lot of ideas but nothing has fixed my high idle......it idles at 1100-1200 when fully warm and also sometimes acts like it has a vacuum leak, dropping from 1200 to 800 and back up etc......it is a z6 block, with a y8 head, z6 intake manifold, b18a1 tb.......ive checked the idle adjusment screw, the butterfly adjustment screw, eacv has been cleaned, map and tps arent switched....the only ideas i have are.....A) im using a y8 head, z6 intake manifold, and a z6 IM gasket, is that causing a leak? or B) im using a b16 tb gasket and that might make a leak? or any other suggestions....thanks!
its in a ef hatch obd0
Old Jul 11, 2004 | 08:34 PM
Default Re: cant fix high idle on z6/y8 in an ef with b18a1 tb SEARCHED (B18TurboEF)
bump!!!
Old Jul 12, 2004 | 01:49 PM
hondaZvic's Avatar
um... if u think the gasket is not working.. u can make ur own out of gasket material. that way u can make it fit perfectly. gasket material = $cheap$
Old Jul 12, 2004 | 03:15 PM
i still cant fix it!!
Old Jul 13, 2004 | 09:24 AM
hondaZvic's Avatar
does ur tb have a "fast idle valve" on the bottom of it? i cant remember if b18 tbs have this or not.?...??????
Old Jul 20, 2004 | 05:49 PM
EF9 CiviC SiR's Avatar
Default Re: cant fix high idle on z6/y8 in an ef with b18a1 tb SEARCHED (hondaZvic)
use your si a6 manifold i had the same problem
Old Jul 20, 2004 | 07:04 PM
Default Re: cant fix high idle on z6/y8 in an ef with b18a1 tb SEARCHED (EF9 CiviC SiR)
nah i fixed it....just put a piece of soda can inbetween the eacv and manifold....my eacv is bad....
bklounge30
Sep 16, 2011 06:56 PM
thedanny88
Dec 9, 2008 12:53 PM
MildWater
21
Mar 7, 2007 12:27 AM
Infinite Auto
17
Jul 12, 2004 11:34 PM
egturbo
Jun 19, 2004 07:07 PM
