compression #'s (z6 block + y8 head + y8 headgasket + 9.0:1 pistons)
Old Jul 11, 2004 | 05:45 PM
pip9's Avatar
Default compression #'s (z6 block + y8 head + y8 headgasket + 9.0:1 pistons)
I'm thinking my compression is alittle higher than i should have. I'm running a z6 block with a y8 head with the thinner y8 headgasket. The head was resurfaced also. The pistons are 9.0:1 cp's. Anyone have an idea of what the compression #'s are with this combination?
Old Jul 11, 2004 | 06:19 PM
Kelly.'s Avatar
I've quit using this account
not sure what your compression #'s should be, but i was told the y8 head combustion chamber is smaller then the z6. simliar to ls-vtec effect on c/r.
i was told that z6 block + y8 head+ 9.0 c/r pistons= a c/r of ~9.5 (with un milled head)
^^^^ told to me by Jeff (boosted hybrid)
maybe this will explain why your seein higher then normal numbers?
hope i helped.
Old Jul 11, 2004 | 06:20 PM
JonGP4's Avatar
Default Re: (llewsirc)
10.245544451625258:1
per compression calculator
http://www.knology.net/~jediklc/D.htm
Old Jul 11, 2004 | 06:25 PM
M.A.R.C.'s Avatar
Default Re: (JonGP4)
llewsirc is right... it should be somewhere around there.
to use that calculator right you need to get the dish volume of the 9:1 pistons (JE lists them on their site) and enter it as "other." if i remember right... 9:1 JE/SRP's for a Z6 have a dish of -11. also remember if u have an overbored motor the volume would be different.
Old Jul 12, 2004 | 02:51 PM
pip9's Avatar
Default Re: (CivicRyda2k)
I have 75mm cp's now my srp's melted. So is this c/r going to be too high for 15psi? I'm not sure how my srp's were destroyed. I dont want to melt my new ones. I never noticed any detination on the way to get it tuned or while it was being tuned so i'm really confused as to why they burned up. I only got on it twice on the way up and none on the way home b/c it was overheating on me. btw..compression #'s were 185-190 range before my trip to the dyno and then 135-140 when i got home.
Old Jul 12, 2004 | 03:02 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (pip9)
overheating = not good
cant explain the drop in comrpression after your trip other than your eating those ones up too . whats your timing at? what kind of gas are you running? i melted a stock piston from bad gas
Old Jul 12, 2004 | 03:21 PM
pip9's Avatar
Default Re: (Hella_JDM)
the overheating was another d-series head lifting issue but it was b/c a headstud stripped out. those pistons that were in the car at the time of the tune were my srps. I just bought new cp's this past week. My timing was at 7-9 btdc before going to get it tuned. We found out my engine builder set my timing off a tooth so we adjusted my cam gear to get it to 16 btdc. Im running 93 octance gas. There were no signs of knock or anything on the dyno and i did not notice anything on the drive up (no radio or anything so i sure i would have noticed it).
Old Jul 12, 2004 | 03:22 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (pip9)
that timing sounds way retarded....
Old Jul 12, 2004 | 03:35 PM
pip9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">that timing sounds way retarded....</TD></TR></TABLE>
lol...it sure was. the compression numbers stayed the same up until i took it to get tuned. I was running the hack for awhile going to the track a lot too. I didn't have any overheating problem before the drive up to get it tuned also
Old Jul 12, 2004 | 04:55 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (pip9)
do you still have your spec sheet? can you scan it or take a pic for me?
Old Jul 12, 2004 | 05:10 PM
pip9's Avatar
i built my motor myself this time. A honda tech helped me build my motor last time. so i have no spec sheets for anything.
dravesef
11
Nov 12, 2007 05:25 PM
turbo sol
Feb 23, 2005 06:03 PM
ej8
Apr 17, 2003 06:34 AM
Ash J. Williams
Oct 3, 2002 10:56 AM
