another iridum sprak plug question for LS turbo
Old Jul 11, 2004 | 03:21 PM
knightnam's Avatar
Default another iridum sprak plug question for LS turbo
ok, i've done a little research and i can only find plug information about gsr's
i just recieved a set of NGK Iridium IX's
they are zfr5fix-11 stock #2477
my question is are these plugs good for a turbo LS or are there better ones that i can buy. or should i not even waste the money and just use these NGK ones i have
Old Jul 11, 2004 | 03:24 PM
DRAGLS's Avatar
Default Re: another iridum sprak plug question for LS turbo (knightnam)
are you boosted?
Old Jul 11, 2004 | 03:27 PM
knightnam's Avatar
Default Re: another iridum sprak plug question for LS turbo (DRAGLS)
yes revhard kit for the b18b
Old Jul 11, 2004 | 03:32 PM
DRAGLS's Avatar
I do not recommend that you use that heat range plug and you don't want to use a
projected tip plug. Here are the iridiums u want to use (NGK)
stick with these:
bkr6eix -6418
bkr7eix -2667
bkr8eix -2668
bkr9eix -2669
Old Jul 11, 2004 | 03:33 PM
knightnam's Avatar
what would be the best for my application
Old Jul 11, 2004 | 03:39 PM
DRAGLS's Avatar
it really all depends on how much power you are running thru it? The stock heat range is a #5, for every 75-100 hp increase you want to step down one heat range
so that would be a #6 and so on! you also don't want to run to cold of a plug because they will foul real easy.
So I would go with a #6 maybe a #7 if you are beyond 12psi
oh_dam
Mar 17, 2010 04:53 PM
81CB900C
Aug 16, 2007 09:07 AM
TEG777
Jun 19, 2005 08:29 PM
sleepyhamsterlx
Feb 18, 2003 06:59 PM
FoCaL
Feb 4, 2003 01:47 PM
