What should be my next step?
What should be my next step in my swap?
Specs:
92' DX HB
JDM B16A2 00'
ITR Intake manifold
ITR Throttle body
AEM Short air
Fluidyne radiator
Nology Hotwires
Competition Clutch / Flywheel Stage 4
What would be your next move into making more hp/torque?
Thanks in advance for your help.
Specs:
92' DX HB
JDM B16A2 00'
ITR Intake manifold
ITR Throttle body
AEM Short air
Fluidyne radiator
Nology Hotwires
not to be an ***, but theres no such thing as a 2000 JDM B16a2.
i would go with a sick *** header, like a comptech or hytech. that would give you huge gains, especially with torque.
no other mod will give you as much as it is capable of unless you get a better header.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chronodyne28 »</TD></TR><TR><TD CLASS="quote">I would decide whether or not if I want all motor or turbo. If you're going all motor then by all means get headers and do your piping if you already haven't.</TD></TR></TABLE>
just what he said and a stock fuel rail will do fine the aem and str and so on they are just for looks unless your making like over 450+ hp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe »</TD></TR><TR><TD CLASS="quote">headers and CTR cams
enough said if your going all motor
</TD></TR></TABLE>enough said if your going all motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmdxhatch »</TD></TR><TR><TD CLASS="quote">Currently have the DC 4-1 ceramic. Is there a better one? Or will this do?</TD></TR></TABLE>
there's a huge thread about 4-2-1 vs 4-1 header a way back. there are differences in top-end/low-end power or something like that between them...i forgot.
From what I understand the 4-2-1 header gives power on the low-end range. The 4-1 is high-end but the 4-1 header can give better power in the low and high range if the motor is mildly to heavily modified. 4-1 is typically for drag.
91integraLSVTEC
Sep 28, 2004 07:21 PM
