air conditioning removal from eg
Old Jul 11, 2004 | 01:36 PM
untitledsn41's Avatar
Default air conditioning removal from eg
i tried searching and only found things for sale and wtb... how do i remove the a/c out of my eg hatch. i'm doing my swap right now and i dont like messing with it because both of the lines are pressureized. please help asap
b18c in eg on its way...if i could figure out the a/c
where to start?
Old Jul 11, 2004 | 01:39 PM
Ignitecivic's Avatar
Default Re: air conditioning removal from eg (untitledsn41)
first take out the ac belt by loosening the ac pulley. then unbolt the ac compressor, i think there are 4 long bolts.
Old Jul 11, 2004 | 01:41 PM
articbluedc5's Avatar
Default Re: air conditioning removal from eg (Ignitecivic)
I cut my ac belt, undid the 4 bolts 2 on top two on bottom, and they you unhook the lines. If your system is full your refridgerant will leak out just pull it out quick. If you look in the haynes they should tell you step for step
Old Jul 11, 2004 | 02:35 PM
im nervous doin it because the lines are presureized. when i take out the bolts where is all the fluid/pressure going to go. the person i am working with doesnt feel comfortable working with it and now im stuck!
Old Jul 11, 2004 | 04:09 PM
CTREGSIX's Avatar
just stick a screw driver or something to hold the release valve down in the nipple to release the pressure it should be ok..just dont stick around i heard its bad for ur health..
Old Jul 11, 2004 | 04:29 PM
b18bcivic's Avatar
you'll regret it
Old Jul 11, 2004 | 04:41 PM
Grip's Avatar
Default Re: air conditioning removal from eg (b18bcivic)
IN A WELL VENTELATED AREA: before you do anything remove the pressure from the lines..use a long screw driver or somthing that can depress the pin under the refill cap(green/blue or black cap) standing out of the way extending your arm depress the pin...if your standing right above the hole expect to get sprayed with stink..once all mist/pressure is removed proceed to dissamble.
dont be scared its nothing more then spraying a can of spray paint or hair spray just dont be in front of the nozzle when you spray it or youll get sprayed..yes it is polluting but its very easy and very fast and dosent cost anything if you get caught i dont know you
Old Jul 11, 2004 | 11:23 PM
BatuKing's Avatar
If your car is just sitting then your pressures are not that high.. ususally somewhere close to the ambient temp. So if you want to do the ILLEGAL thing and vent it do it in the morning.
IMHO call and AC shop and tell them to remove it.. if it's R12 I guarantee they will do it for free.
Old Jul 25, 2004 | 05:44 PM
.Ryan's Avatar
Don't Trust Anyone
Default Re: air conditioning removal from eg (BatuKing)
Is a 96 the same way? Anything else that can be removed?
Old Jul 25, 2004 | 05:52 PM
kevinEGcivic's Avatar
hello! im interested to buy your a/c if all the components are woking.
tallguy21
Mar 8, 2012 02:02 PM
Declectic
Jul 9, 2004 11:59 AM
