maintenance: spark plugs @ 55k mi.
Old Jul 11, 2004 | 10:03 AM
kepani's Avatar
Default maintenance: spark plugs @ 55k mi.
yesterday i changed out my spark plugs at 55k mi.
part number 98079-5614h (ngk platinum pfr6g-11).
i noticed (facing motor) that the plugs were noticably more corroded/dirty from the left cylinder to the right. also, when i peered into the plug ports, i noticed a lot of dirt/debris.
anyone have any ideas on why the two far right cylinders were much more fouled? pics below.
far left plug - relatively clean.
far right plug - lots of brown stuff that appeared to be dirt?
fouled plugs - left to right facing motor.
again, from the pics, the plugs are noticably dirtier on the pulley side of the block. any ideas?
i noticed a big difference after changing them out along with replacing the distibutor cap and rotor.
kepani
Old Jul 11, 2004 | 10:19 AM
kepani's Avatar
Default Re: maintenance: spark plugs @ 55k mi. (kepani)
also if it helps, these are original plugs when the car was purchased.
daily driven ~35mi. roundtrip
5 track hpde's
kepani
Old Jul 11, 2004 | 10:30 AM
Big Teggie's Avatar
Do you pressure wash your motor? Sometimes water can get by the spark plug wire tops and sit inside.
Old Jul 11, 2004 | 10:55 AM
kepani's Avatar
Default Re: maintenance: spark plugs @ 55k mi. (Big Teggie)
i don't wash using high pressure. however, once in a while i'll use the filtered water from the diy wash garages. :hmm:
but i still find it strange that the right cylinders are dirtier than the left ones.
the plugs are rusty on the right...and clean on the left.
Old Jul 11, 2004 | 10:56 AM
yoshi234's Avatar
I shoot brides
oddness!
Old Jul 11, 2004 | 12:00 PM
B2FiNiTY's Avatar
About time you changed your plugs. I would have changed them at 25k or 30k miles already. Along with all the other spark stuff minus the wires.
Old Jul 11, 2004 | 12:54 PM
Sinbro2's Avatar
Default Re: maintenance: spark plugs @ 55k mi. (B2FiNiTY)
i change plugs every 1-1.5 miles in our drag ITR
for about time you changed those plugs
Old Jul 11, 2004 | 05:35 PM
Louie's Avatar
What would Chente do?
Default Re: maintenance: spark plugs @ 55k mi. (sinbro2)
it's just from trapped moisture that caused the rust over time. Ever do a valve adjustment? Possible to leave the spark plug wire boots a little loose.
Old Jul 11, 2004 | 06:26 PM
Nishant's Avatar
Default Re: maintenance: spark plugs @ 55k mi. (Louie)
my spark plugs and wires went bad at 7k miles. yes 7k, acura replaced all of them and wires under warranty. they couldn't figure out why it went bad, neither could I
Old Jul 11, 2004 | 07:19 PM
Mires's Avatar
Default Re: maintenance: spark plugs @ 55k mi. (swtxaznrac3r)
Ive noticed something like that myself. A couple of times when it rained real heavy I got a little water in the spark plug cavity which was causing the car to misfire. After looking in there I noticed there was a little pool of water in the 2 on the right. The other 2 had some also but only about half as much as the right 2.
Old Jul 12, 2004 | 11:07 AM
Ill's Avatar
Ill
Way overdue for a plug change. The electrodes are not horrible, but they are definitely worn. I don't see anything to indicate internal problems, as I was made to think by reading the text (key word: fouling).
The rust is definitely from water sitting in the plug 'bay' or whatever you call that channel in the ITR valve cover. Don't wash your motor so much, it's not good for it. If you do wash it, bag the electrics first (dizzy, fuze blocks, etc)., dont use high pressure (or any significant pressure), and then drive it after to dry it out.
Old Jul 12, 2004 | 11:13 AM
mikesaRRRR's Avatar
it will run lots better once its all done
Old Jul 12, 2004 | 12:15 PM
ebelp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kepani &raquo;</TD></TR><TR><TD CLASS="quote">yesterday i changed out my spark plugs at 55k mi.
part number 98079-5614h (ngk platinum pfr6g-11).</TD></TR></TABLE>
Are those the plugs that R's come with from the factory?
Old Jul 12, 2004 | 12:54 PM
B2FiNiTY's Avatar
Default Re: maintenance: spark plugs @ 55k mi. (ebelp)
I believe they come with Denso's from the factory but those NGK are the oem replacement ones.
Old Jul 12, 2004 | 03:12 PM
jmk2888's Avatar
I use NGK platinum pfr7g-11 which are stock on my 96 JDM ITR Engine.
Old Jul 12, 2004 | 09:12 PM
kepani's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Louie &raquo;</TD></TR><TR><TD CLASS="quote">Ever do a valve adjustment? Possible to leave the spark plug wire boots a little loose.
yeah, did valve adj. at around 28k mi. probably didn't "snap" the covers back on too good. thanks louie! was just wondering if i had to worry about anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mires &raquo;</TD></TR><TR><TD CLASS="quote">Ive noticed something like that myself. A couple of times when it rained real heavy I got a little water in the spark plug cavity which was causing the car to misfire. After looking in there I noticed there was a little pool of water in the 2 on the right. The other 2 had some also but only about half as much as the right 2.</TD></TR></TABLE>
not that it's a good thing - though i'm glad it's more common than i had thought.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikesaRRRR &raquo;</TD></TR><TR><TD CLASS="quote">it will run lots better once its all done</TD></TR></TABLE>
yup, definitely noticed some newfound "spunk".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I believe they come with Denso's from the factory but those NGK are the oem replacement ones.</TD></TR></TABLE>
hmm...i guess the 2001's got shafted? the ngk's in the picture are my original plugs.
kepani-who thanks da h-t membahs again.
Old Jul 12, 2004 | 09:17 PM
B2FiNiTY's Avatar
The 01 that I know of came with Densos. I thought it was very odd that it did because I thought it was common knowledge that they came with NGK.
ScottF
Feb 21, 2010 10:49 AM
Dartanian
May 13, 2006 05:26 AM
JDM_lover03
Aug 15, 2005 10:14 AM
ILLICON3000
Sep 20, 2004 07:45 AM
mattmw88
Feb 22, 2002 07:54 AM
