What boost should i run
i have a 94 delsol and here is my setup...what kinda boost could i run ?
HP Range?
B18C block with darton sleeves and GSR crank
Manley Connecting Rods - Hold 600hp
JE Pistons 9:1 Compression 81mm Bore w/ Rings
GSR Water Pump
GSR Oil Pump
New Rod and Main Bearings
New Thrust Washers
ARP head studs
Greddy Oil line kit
New Head Gasket
Drag 3 Turbo kit
440CC injectors
AEM fuel rail
XS fuel pressure regulator 1:1
HP Range?
GSR Water Pump
GSR Oil Pump
New Thrust Washers
ARP head studs
Greddy Oil line kit
New Head Gasket
Drag 3 Turbo kit
440CC injectors
AEM fuel rail
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kKdARIAN »</TD></TR><TR><TD CLASS="quote">umm.. what fuel managment? I hate these questions.. why do you have a motor built and not know what kind of HP your looking to put down? </TD></TR></TABLE>
agreed you shouldnt be looking ho much boost you can run you should set an hp goal
i say you could run around 15-17psi max i think that is an estimate, i think yu could put down around 450 hp if it is TUNED CORRECTLY.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">i say you could run around 15-17psi max i think that is an estimate, i think yu could put down around 450 hp if it is TUNED
CORRECTLY.
Not with those 440's! Maby 320-360??
CORRECTLY.
</TD></TR></TABLE>Not with those 440's! Maby 320-360??
KeyserSoze
Jul 13, 2005 07:45 PM
