mini cooper wheels - would they fit on a DC2?
i stopped and had a look at a neat, little british racing green mini cooper s and noticed it the wheels might fit on my '98 DC2. they were four lug, but looked a little wider and might rub. do you guys have and idea if they'd fit? i'm just curious.
thanks.
thanks.
yup. they fit. the new mini coopers have 4x100 pcd and the hub bore is nearly identical to integras. only thing is that you have to run tappered lug nuts.
My bro and I swapped wheels for the hell of it once
Cooper S <---> Gen 3 teg Same Offset and bolt pattern.
the Only problem is, he has 195/55/16 rubber.. the tire is a bit too tall and rubs the hell out of my wheel well. The rim off the cooper s is only a 16x6 wheel,I run a 16x7 at roadcourse events. if you are talking about the 17 inch optional cooper rim, it's a 17x6.5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Interesting! That would be a unique setup. </TD></TR></TABLE>
agreed. i'd like to see some pictures if anybody has them. what's the going rate on used mini cooper wheels?
spooncivic01
Dec 28, 2006 06:05 PM
.RTErnie
Mar 20, 2003 01:52 PM
