Help Quickly, timing belt issue.
Old Jul 10, 2004 | 01:11 PM
MooreBoost's Avatar
Default Help Quickly, timing belt issue.
Ok, new problem. What timing belt cover do I use for a DOHC ZC?
Modified by tegunderpressure at 12:30 AM 7/11/2004
Old Jul 10, 2004 | 01:18 PM
4gCRX's Avatar
You take the pulley off first then line it all up:
http://www.c-speedracing.com/h...t.php
Old Jul 10, 2004 | 01:28 PM
MooreBoost's Avatar
Default Re: (4gCRX)
Then what keeps the engine from just turning over as you try to remove the crank pulley? Wont it just keep spinning as you turn the socket?
Old Jul 10, 2004 | 01:32 PM
stevescivic's Avatar
Default Re: (tegunderpressure)
what I did was remove the started, jam the flywheel with a crowbar and the reef on the crank pulley bolt with all of my body weight.
That bolt is on super super super tight and you'll likely have difficulty getting it off.
The other alternative is the buy a crank pulley holder from honda. It shouldn't be too expensive.
Old Jul 10, 2004 | 01:42 PM
eda6's Avatar
Default Re: Help Quickly, timing belt issue. (tegunderpressure)
Get an impact gun. Air or electric will do.
screwdrivers and allan keys dude that crazy.
Sticking **** in the flywheel isn't a good idea either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevescivic &raquo;</TD></TR><TR><TD CLASS="quote">
I tried to get this from honda. They said they didn't sell them.
If you got this item from honda chime in.
Old Jul 10, 2004 | 02:37 PM
MooreBoost's Avatar
Default Re: Help Quickly, timing belt issue. (eda6 hb)
See first post.
Old Jul 10, 2004 | 03:42 PM
4gCRX's Avatar
I put a 2" nut just inside the pulley hub and hold the nut with a wrench. Then I stick the socket/extension through the nut hole and onto the pulley bolt. Bolt is on extremely tight...electric impact gun worked for me.
Here's one tool: http://www.drivewerks.com/cata...4.htm
Honda Factory Style Holder:
http://www.autospecialtytools....1.dht&
Just pulled those two places off the net, dunno anything about them but the tools are all over the place.
Modified by 4gCRX at 7:55 PM 7/10/2004
Modified by 4gCRX at 7:56 PM 7/10/2004
Powered by VTEC
Jan 29, 2008 05:58 PM
EG2Driver
Jun 15, 2006 07:24 PM
crxcess
Feb 19, 2004 08:24 PM
NAZC
11
Jan 15, 2003 04:52 AM
h46it
Mar 21, 2002 07:57 AM
