Gauge Cluster
Old Jul 10, 2004 | 08:33 AM
JoeCDN's Avatar
Default Gauge Cluster
Does it matter that I have an auto tranny and gettin a cluster that doesnt show the p.r.n.d etc? and How hard it it to change clusters on a 92 dx?
Old Jul 10, 2004 | 08:36 AM
Luserkid's Avatar
Default Re: Gauge Cluster (JoeCND)
P.R.N.D.? Whats that?
Auto tranny has a tach right? Why the hell do you want to down grade to no tach?
Old Jul 10, 2004 | 08:38 AM
JoeCDN's Avatar
I have an dx cluster right now. NO TACH!
I want a tach!
Old Jul 10, 2004 | 08:39 AM
crashN2u's Avatar
Default Re: Gauge Cluster (Luserkid)
p=park
r=reverse
n=neutral
d=drive
Old Jul 10, 2004 | 08:50 AM
Luserkid's Avatar
Default Re: Gauge Cluster (crashN2u)
opps my bad, i read wrong. I thought you said auto tach instead of autotranny.
You could swap clusters out like everyone else. Just if theres not P.R.N.D on the gauge youll have to look down to see what gear your in. But you should be use to putting it in gear that you dont need to look.
Old Jul 10, 2004 | 01:18 PM
carlton585's Avatar
its easy to swap clusters. when i had my auto cluster (auto-manual conversion) i would drive around in park until i swapped interiors with an si. cluster is easy to take out. pop out hazard switch and clock. take out screw back there. take out 2 above cluster. pull out bezel. remove 4 screws on either side of cluster. remove by tilting it forward. pop out the 3 (?maybe 4) harnesses. and reverse to install the new one.
Old Jul 10, 2004 | 01:28 PM
92b16vx's Avatar
Default Re: (carlton585)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carlton585 &raquo;</TD></TR><TR><TD CLASS="quote"> pop out hazard switch and clock. </TD></TR></TABLE>
clock is screwed in from behind the bezel.
Old Jul 11, 2004 | 07:28 AM
carlton585's Avatar
Default Re: (92b16vx)
oops, yeah forgot about that, oh well he would figure that out.
Old Jul 11, 2004 | 08:29 AM
Uncle Fester's Avatar
cake, swaps right out
Old Jul 11, 2004 | 10:49 PM
JoeCDN's Avatar
Soo if I dont have a clock...should I just take of the cover thing?? And how to I pop off the hazard switch?
Old Jul 12, 2004 | 06:57 AM
ek9800's Avatar
Default Re: (Uncle Fester)
its easy to swap but yopu should keep your tach
Old Jul 12, 2004 | 06:58 AM
ek9800's Avatar
Default Re: (jdm98hb)
opps read the post wrong i thought you already had a tach my bad
Old Jul 12, 2004 | 09:11 AM
95DXCIVIC's Avatar
This is how you should take your cluster off/replace it. I have a DX as well. First thing, is, pop off your hazard switch. To do this take a sharp flat-head screwdriver, or maybe a knife, and stick it in the edge of the entire hazard switch. (Your really popping off the plate, not just that switch. Once you get that out, your going to have a harness on the back of it. Take that off by pushing down the little switch and pulling. Now, check if there is a screw behind the hazard switch, it shouldn't be too unnoticable. I don't remember if there is one or not there. Next step you should take is take out the two screws located on the top of the bezel. They are right above your steering wheel/guage cluster. Ok, next step is to take that screw driver/knife and pry off your entire bezel. It might be a little dificult because you don't want to break anything. There are little clips on the end of the bezel which are holding it in place. Once you have that off, you have access to the wires that connect to the clock, just take those out like you took out the hazard switch lights . Getting your guage cluster removed is very simple. There is four screws, two on each side. Take those off, than pull the guage cluster out some for easier access to the backside of it where you need the to remove the switches. There will be 3-4, not sure exactly how many. They are just like the other switches you removed before. Get those out and your guage cluster is free for you to change. Just swap it out with the new one you have, hook all switches up and you have a new guage working. Oh yah, test it before you assemble everything. Don't want to have to do it again if it was a faulty one.
-Good luck, any other questions just ask.
Voodoo7
11
Mar 25, 2012 05:58 PM
808B18C5
Aug 24, 2011 04:46 PM
ICEMAN707
Apr 13, 2009 07:07 PM
-Bionic-
Apr 25, 2004 06:44 AM
theNewCivicGuy
10
May 2, 2002 03:07 PM
