Is Simple Green safe to use on paint?
Old Nov 21, 2001 | 10:42 AM
ITR_1211's Avatar
Default Is Simple Green safe to use on paint?
Does anyone know if Simple Green is safe to use on paint under the hood?
I have to clean that rustproofing out of my engine bay ASAP.
Thank you,
Old Nov 21, 2001 | 10:46 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: Is Simple Green safe to use on paint? (Darryl Mussashi)
no problem. i use it to clean my engine bay all the time.
Jason's Avatar
under the hood in a diluted form yes...I wouldn't use it straight up as it may eat off some paint...make sure you completely spray it down w/ water afterwards too!
Old Nov 21, 2001 | 10:57 AM
Big Phat R's Avatar
it will remove wax - but it's safe for paint/clearcoat
Old Nov 21, 2001 | 11:05 AM
ITR_1211's Avatar
Default Re: Is Simple Green safe to use on paint? (Big Phat R)
I have a CW, just hope it does'nt turn green!
Wish me luck!
Thanks guys!
Old Nov 21, 2001 | 11:23 AM
B2FiNiTY's Avatar
Simple green is awesome. When I was in my auto class they had CLEAR simple green and I used that stuff like no other.
Old Nov 21, 2001 | 11:51 AM
Rob Dizzle's Avatar
Default Re: Is Simple Green safe to use on paint? (B2FiNiTY)
dilute the mixture as much as possible. if it is not cutting away the grease, then thicken up the mixture with some more SG
Old Nov 21, 2001 | 01:32 PM
Benjamin Tang's Avatar
Default Re: Is Simple Green safe to use on paint? (bob46802)
there is an automotive version of simple green that dosen't need diluting for most stuff. i've used it on the outside paint with no problems
Old Nov 21, 2001 | 02:39 PM
ITR_1211's Avatar
Default Re: Is Simple Green safe to use on paint? (Benjamin Tang)
Benjamin, is it by any chance called simple green pro?
One more question, do you guys think it would be better if I degreased it while it is warm or cold?
Old Nov 21, 2001 | 04:36 PM
my spray bottle just says "simple green automotive" on it... sorry the label got too wet too often and most of it has come off
i think it's best that you do it cold. someone warned me that too much heat can cause adverse/accelerate chemical reactions that would eat the finish?
Old Nov 22, 2001 | 09:26 AM
ITR_1211's Avatar
Thanks Ben, I started yesterday. The stuff lathers up like soap, I have to rub very hard but it does come off very slowly. I could actually see white. I'm about 1/3 there!
I have to use a paint brush for the small crevices. Its a pain in the ***, I keep telling myself I wish I had'nt had started this. Its going to take a lot of time and patience to finish this.
Old Nov 22, 2001 | 10:08 AM
i use a toothbrush. when the toothbrush gets nasty you can use simple green to scrub that up too.
hey i watched that x-files episode... so when did they sew your head back on darryl?
Old Nov 22, 2001 | 11:13 AM
ITR_1211's Avatar
Tooth brush does'nt scratch paint?
They sewed it back on as soon as the episode was over! Surprised you noticed the name!
Old Nov 22, 2001 | 11:39 AM
well, don't go ballistic and it won't... unless there is a lot of gritty stuff in the gunk u are trying to clean off.
how could i forget ms. jade afterglow?
patotas
Paint and Body
May 10, 2009 11:29 AM
97CWITR
Paint and Body
Feb 27, 2008 07:20 AM
DaMmniTz
Jun 10, 2005 08:56 PM
johnzm
Feb 24, 2003 08:37 AM
Koori
Apr 29, 2002 01:49 PM
