5-Lug Conversion
Old Jul 9, 2004 | 06:20 PM
Convoy's Avatar
Default 5-Lug Conversion
im looking to get a 5 lug conversion on my EG, i know i need the whole front hub, front LCA's, front sway bar, and hardware, the rear LCA's and sway bar, and the rear Hub
my question is is there any thing else i need to get this conversion, thanks in advance
also im fully aware about the ongoing debate about how getting the conversion is for show, but i really dont care, i'm getting them because i hate my rear drums and front brakes, which are oem.
Old Jul 9, 2004 | 06:29 PM
eg6ajk's Avatar
Default Re: 5-Lug Conversion (Convoy)
as far as the front, knuckle along with rotor and caliper is the minimum you can get away with.
rear requires complete again hub/along with rotor caliper, ebrake cables and brake lines minimum - but personally I would try to get complete trailing arm as it has new bushing and is much cleaner.
conversion is no different then doing GSR/LS brake swap
http://tech.hybridgarage.com/tech/brakeswap.html
Old Jul 9, 2004 | 06:54 PM
Status Sean's Avatar
Default Re: 5-Lug Conversion (eg6ajk)
make sure u got the brake booster too thats important !
Old Jul 9, 2004 | 06:57 PM
hatchi's Avatar
basically you would want the complete front knuckle *dont need lca as you can use your stock ones.
Complete rear trailing arms with ebrake cables *again you can use your Lca unless you want to change to itr shocks as well.
Old Jul 9, 2004 | 07:01 PM
Convoy's Avatar
thanks for the replies
hatchi: i'm going to be using the ITR LCA's because i will be using the sway bars
Old Jul 9, 2004 | 08:43 PM
JDM R's Avatar
Default Re: (Convoy)
youre gonna need to change your shocks then
Old Jul 9, 2004 | 09:53 PM
Sliced Beard's Avatar
Default Re: (JDMar)
you can use GSR lower control arms with the ITR rear sway bar and not have to buy new shocks
Old Jul 9, 2004 | 10:31 PM
Dengar's Avatar
[QUOTE=eg6ajk]
QUOTE]
Suppose that you already have a gsr upgrade, how much more would you need to go up to 5 lug?
Sorry to jack thread, but the thought of gunmetal itr wheels on my car puts a smile on my face.
Old Jul 9, 2004 | 10:55 PM
Default Re: 5-Lug Conversion (Dengar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">as far as the front, knuckle along with rotor and caliper is the minimum you can get away with.
rear requires complete again hub/along with rotor caliper, ebrake cables and brake lines minimum - </TD></TR></TABLE>
Old Jul 10, 2004 | 08:24 AM
Convoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dengar &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=eg6ajk]
QUOTE]
Sorry to jack thread, but the thought of gunmetal itr wheels on my car puts a smile on my face.</TD></TR></TABLE>
then all u need is the knuckles.
Old Jul 10, 2004 | 11:45 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Remember you will be adding 45lbs tot he car and adding sprung weight!
https://honda-tech.com/zerothread?id=915556
i took my 5 lug off!!!!! went back to my old 4x114 ITR set up
Old Jul 12, 2004 | 10:32 AM
Convoy's Avatar
Default Re: 5-Lug Conversion (SnoFlake EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnoFlake EG &raquo;</TD></TR><TR><TD CLASS="quote">Remember you will be adding 45lbs tot he car and adding sprung weight!
i took my 5 lug off!!!!! went back to my old 4x114 ITR set up</TD></TR></TABLE>
might be, but im getting a killer deal on it.
i'll just lose 45 pounds myself
Old Jul 12, 2004 | 10:41 PM
MonkeyManStunna's Avatar
hey i have a question since it deals with this topic with a 03 rsx type s 5 lug conversion fit my 00 si?
Old Jul 12, 2004 | 11:25 PM
wdskuk's Avatar
Hey Convoy. Who are you getting the 5 lug setup from.
Old Jul 12, 2004 | 11:39 PM
poison's Avatar
http://tech.hybridgarage.com/tech/brakeswap.html</TD></TR></TABLE>
pshh, this is comin from an ex 5 lugger!
my ex clone!
Old Jul 12, 2004 | 11:40 PM
SE+EK's Avatar
Default Re: (wdskuk)
5 lug - Is it worth it?
Old Jul 13, 2004 | 07:42 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: 5-Lug Conversion (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">
my ex clone!</TD></TR></TABLE>
actually im the X 5 luggin and your X clone!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloSilverEF &raquo;</TD></TR><TR><TD CLASS="quote">5 lug - Is it worth it? </TD></TR></TABLE>
it depends on how you look at it...the brakes are well worth it, but it will boil down too how you drive, what racing if any you do, and if you just want the JDM BLING.....
Modified by SnoFlake EG at 10:23 AM 7/13/2004
Old Jul 13, 2004 | 09:21 AM
Convoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wdskuk &raquo;</TD></TR><TR><TD CLASS="quote">Hey Convoy. Who are you getting the 5 lug setup from.</TD></TR></TABLE>
i dont know yet, i found someone in WI selling it cheap
Old Jul 13, 2004 | 10:36 AM
wdskuk's Avatar
how much
Old Jul 19, 2004 | 10:47 PM
Default Re: (sloSilverEF)
YES YES IT IS !!!!!!
xxi2icexx
Jan 26, 2012 10:51 PM
los02
Mid-Atlantic (Sales)
Aug 12, 2009 07:24 AM
96dxpower
Northern California (Sales)
Feb 20, 2007 06:15 PM
RACEPAK
Jan 8, 2005 03:37 PM
import palace
Apr 19, 2003 10:02 AM
