92' Accord LX--2 Electrical Problems
Old Jul 9, 2004 | 03:22 PM
Frisco's Avatar
Default 92' Accord LX--2 Electrical Problems
Hey Gang!
These 2 problems are unrelated as they started at separate times.
1) All of these things stopped working at the same time: Intermittent Windshield Wiper, Rear Defroster, Door Chime, Power Antenna. I assume they must be on the same circuit. I checked all fuses, but they are all good. Any ideas on cause and fix.
2) This second problem only happens in cold weather and the colder outside the worse. My Blinker/Turn Signals take several seconds to come on (especially the left one). They just click for a few seconds before they start working. If it's freezing outside it can take them more than 1 minute to come one.
I already had a mechanic replace the Flasher, but this didn't help.
Any suggestion greatly appreciated!
Frisco
Old Jul 11, 2004 | 02:30 PM
Frisco's Avatar
Default Re: 92' Accord LX--2 Electrical Problems (Frisco)
bump
Old Jul 11, 2004 | 10:44 PM
alb_accord's Avatar
its electrical. check all the fuses in the engine compartment and the fuses under the steering wheel. and check the relays too which are located at the same places.
Old Jul 12, 2004 | 05:10 AM
ex90ranger's Avatar
I have been having problems finding any one with really good first hand knowledge of the electrical system on these things also. No one can seem to tell me or even give me a lead on my wiper problems. Sounds very much like what you’re having problems with. If I turn my wipers on in the morning when the car is cold it could take them up to 3 mins to respond no matter what you set the switch to. But if you turn them off they sweep once like they are going back to park. And if I turn the switch on again before they return to park they will stop where ever they are. But once they start to respond like they should I never have a problem with them again until the car is cold. Even the dealer can't give me any place to start looking.
I guess once I get my ranger back on the road I will have to rip into this thing and figure it out.
Old Jul 12, 2004 | 05:09 PM
SearchBeforeUPost!'s Avatar
Default Re: (ex90ranger)
If all of the fuses are ok, I would start with the multi function switch and then the wiper relay.
Old Jul 13, 2004 | 09:46 AM
mrvinyl33's Avatar
New User
Re: #2. I have also seen this happen occasionally (more so when colder) on my '92 Accord LX. My local dealership advised its related to the wand in the steering column. They said replacing it would take care of this problem. Right now it hasn't happened in awhile, so I left it as-is.
Old Jul 13, 2004 | 03:58 PM
Frisco's Avatar
Default Re: 92' Accord LX--2 Electrical Problems (mrvinyl33)
Thank You and everyone else for the tips!
I have never heard of this "wand." Did the dealer give you any idea of the cost of replacement?
I appreciate everyone's help!
Old Jul 13, 2004 | 07:06 PM
alb_accord's Avatar
its the level thing that u use for ur turn signal and for the lights. its a lever and a black box which u can see because its a attached to the steering colon. its a hole asambly. just buy one in a junk jard.
daughterscar
Mar 12, 2019 02:46 PM
Nick Mullins
May 8, 2016 06:21 PM
92_Accord_LX
Nov 13, 2009 05:13 PM
thorclark
Apr 10, 2008 07:23 AM
johnfrisco
Sep 5, 2005 12:13 AM
