eagle rods with CP pistons...for those who have these set-up
ok im about to install eagle rods with CP pistons. am i supposed to install spacers on the dowel pin on either side of a rod? i dunno how to explain well. im concerned because theres so much side to side play when the rods are on the pistons.
also how do i take the OEM dowel pins out of OEM pistons? looks like theres 2 dowel pins per piston/rod.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B00STED »</TD></TR><TR><TD CLASS="quote">ok im about to install eagle rods with CP pistons. am i supposed to install spacers on the dowel pin on either side of a rod? i dunno how to explain well. im concerned because theres so much side to side play when the rods are on the pistons.
also how do i take the OEM dowel pins out of OEM pistons? looks like theres 2 dowel pins per piston/rod.</TD></TR></TABLE>That is what those little sprung steel C clips are for. You got 8 of them. They fit into the grooves cut into the piston pin area. They hold the piston pin in place so it won't slide out and hit the cylinder. You install one of them in the piston, slide the pin thru the other side and through the rod. Then install the C clip on the other side. This is going to be hard for you to do the first time. Be careful the C clip does not go flying out on you as you do this. As to rod placement, the bearing tang sides face to the exhaust side.
As to your stock pistons the pins must be pushed out with a press.
Rockin custom CP's and eagles for 400 miles now in my F22 - so far so good. Thumbs up to Earl, helped me out on which way the bearing tangs faced too
Vagitarian
Sep 14, 2012 02:14 PM
StupidSlowRSX
Jan 27, 2005 08:37 PM
