main relay help.
Old Jul 9, 2004 | 12:21 PM
phatrick2332's Avatar
Default main relay help.
Alright heres what the cars doing..its cranking, and not getting fuel, but getting lots of spark. The main relay is like buzzing, clicking, type deal. At the exact same time that the main relay is clicking, the fuel pump is making a funny noise, If i put my hand over the fuel pump, i can feel it humming, then it quits when the relay quits, then starts when the relay starts again.. but really quick. Im wondering if possible ground issue? Which wire is the ground out of the main relay, and off the fuel pump, so i can just ground them both to the chassis and see if anything happens.
sorry about the long post
thanks
pat
Old Jul 9, 2004 | 12:40 PM
DXDOHCVTEC's Avatar
You should take out the main relay, take off the cover and check out the solder on all the points on it they may need to be re-soldered.
Old Jul 9, 2004 | 01:05 PM
I stripped the covering off the ground that runs from the main relay, ran a wire to the - on the battery...fired right up, but only revved to 2k cuz i have no tuning and 450cc injectors lol
ckirso
Mar 18, 2013 08:08 AM
3easy21
Jun 11, 2012 07:27 PM
Domnificent
Jul 11, 2010 10:29 AM
markvqwerty
Aug 27, 2004 08:52 AM
Steve
Aug 29, 2001 06:38 PM
