fuel into filter, but not out (on swap)
I'M DOING A MOTOR SWAP AND TRYING TO START IT UP NOW. FUEL IS GOING TO THE filter but its not coming out at all. I took off the exit line to fuel rail and nothing happened. I took off hte nut AT the fuel rail and still nothing happened. But when i take off the line going IN TO the filter, gas spews out.
what gives??
what gives??
undo the line from the filter to the fuel rail and turn the ignition from I to II a few times to run the fuel pump, then check to see if fuel is coming out
moonpieboy
Oct 9, 2005 09:57 AM
