SC61 trap speeds and psi level..?? DISSAPOINTED...!!
Old Jul 8, 2004 | 08:00 PM
92HB_HB's Avatar
Default SC61 trap speeds and psi level..?? DISSAPOINTED...!!
I jsut want to know how fast you guys w/ sc61's have trapped in the 1/4 , specifically at about 15-17 psi of boost...
I only managed to muster a best of 109 mph in my 4dr teg and am very very dissapointed.. my best ET of the day was a measely 13.0
my setup consisted of:
84 mm sleeved gsr
9:1 weisco pistons/eagle rods
JG IM
hondata s200b tuned to 17 psi on pump gas (350 hp 240 tq)
SC61, pte 600 hp FMIC
full 3" exhaust
2.5 charge piping
REV valve springs/retainers
MSD blaster2 coil
94 LS 4dr / full interior
(was running 24.5/8.5/15 MH slicks and 205/50/15 BFG DR's; ran better w / the bfg's GO figure..)
besides the weight of the 4dr, i dont know why i ran so bad, i'm so bummed too.. may just have to throw it in my hatch to see what it can do...
ARRGHH..
Old Jul 8, 2004 | 08:10 PM
drvfast's Avatar
Default Re: SC61 trap speeds and psi level..?? DISSAPOINTED...!! (92HB_HB)
Something is wrong some where. Not sure exactly what it is though. What was you 60ft by the way.
Old Jul 8, 2004 | 08:11 PM
Mase's Avatar
you only made 350 whp at like 17 psi? that seems low for a 84 mm gsr and sc61
Id go back and look the tune over.
Old Jul 8, 2004 | 08:15 PM
92HB_HB's Avatar
Default Re: SC61 trap speeds and psi level..?? DISSAPOINTED...!! (Mase)
it was a conservative tune and tuned on a Mustang dyno..
Old Jul 8, 2004 | 08:16 PM
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HB_HB &raquo;</TD></TR><TR><TD CLASS="quote">(was running 24.5/8.5/15 MH slicks and 205/50/15 BFG DR's; ran better w / the bfg's GO figure..)
24.5" slicks are possibly too big for ur setup since u pulled a better time with the 205/50/15's which is comparable to a 23" slick
what tranny?
Old Jul 8, 2004 | 08:26 PM
b18cx's Avatar
Default Re: SC61 trap speeds and psi level..?? DISSAPOINTED...!! (Sp00n'd Supra)
last year:
Stock JDM GSR (10.6:1)
SC61
320whp @ 8.5 psi. pump gas
ran 11.40's @ 120-123mph all day in a hatch. 1.60's 60' all day. 24.5x8.5x13 MH slicks
this year:
83mm B18c
10.5:1 (fully built)
483whp @ 17 psi (20-22psi final, but AEBS head studs stretched) race gas
More to come.
Old Jul 8, 2004 | 08:29 PM
ELSpool's Avatar
Something is off, i ran the time in my sig with only 270whp, also tuned on a mustang. My car is a 4dr (2650lbs w/o me), on 23 inch M&H, 1.8 60fts
Old Jul 8, 2004 | 08:37 PM
Mase's Avatar
Default Re: (ELSpool)
are you sure you are holding high boost?
Old Jul 8, 2004 | 08:39 PM
alpha's Avatar
Hmmm ... Are you able to get down and look at the scribing on your compressor outlet?
Old Jul 8, 2004 | 09:11 PM
DD_JonnyLee's Avatar
Default Re: SC61 trap speeds and psi level..?? DISSAPOINTED...!! (0x64)
ive ran a best of 95 mph in the 1/8, if that helps, at 10-11 lbs
317@10lbs
Old Jul 9, 2004 | 03:00 AM
Adriano's Avatar
Same thing happened to me. At 18lbs/380whp with falken azenis street tires, i ran a 12.9 @ 118mph. 2 weeks later, i went to the track with c16 21lbs/445whp with 24.5-8-15 m/t slicks and ran 13s with a best of 112mph. This is a full interior 94 gsr. The tires seems to big, i felt the car husseling to move. Well, tonight i'm going back to the track with some 22-8-15, I will post the results when i get back.
Old Jul 9, 2004 | 04:18 AM
B18C1CYA's Avatar
Default Re: SC61 trap speeds and psi level..?? DISSAPOINTED...!! (brryder)
what where your 60'' times? take a 1 tenth off in your 60'' = drop 2 tenths off your e.t.
Old Jul 9, 2004 | 04:38 AM
nsxmatt's Avatar
24's should be perfect for the power your making. Heck I am blowing off 22's with about 250whp and am upgrading to 24's.
Old Jul 9, 2004 | 04:47 AM
mrbsponge's Avatar
someting just doesnt seem right because you should be trapping higher speeds and lower et's with all that ****, i dont care if it is a teg, i have seen a stock B20 with a 85 shot go faster on radials.......what are you launching at, how is it pulling on the low end, what tranny are you using and what gear are you crossing the clock in?
Old Jul 9, 2004 | 04:58 AM
MIKES's Avatar
Default Re: (mrbsponge)
I would look at the clutch. Sounds to me like its tranny related.
kleefton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">someting just doesnt seem right because you should be trapping higher speeds and lower et's with all that ****, i dont care if it is a teg, i have seen a stock B20 with a 85 shot go faster on radials.......what are you launching at, how is it pulling on the low end, what tranny are you using and what gear are you crossing the clock in?</TD></TR></TABLE>
Agreed.
I bet that thing was not making anywhere close to 350whp.
350whp will land 118-120mph traps, even in the heavier integra body.
Old Jul 11, 2004 | 10:24 AM
92HB_HB's Avatar
Default Re: (MIKES)
clutch is an RPS Max series w/ street disc..
Old Jul 11, 2004 | 10:34 AM
IntegracinGSR's Avatar
Do you have a stock gsr tranny with the open diff? or are you running a LSD?
Old Jul 11, 2004 | 02:43 PM
salt's Avatar
I had this setup:
stock USDM GSR block
stock b16 head
stock b16 tranny
1 bar springs sc61
I went 12.6@ 122 with a 2.1 60'
this was in a 93 del sol about 2500 lbs with me in it.
Old Jul 11, 2004 | 03:06 PM
R THIS's Avatar
Default Re: SC61 trap speeds and psi level..?? DISSAPOINTED...!! (salt)
i went 118.7 mph with my sc61 @ 16 psi... 2.0 litre b18b block and head - 9.0:1 compression... i trapped 111 with my old t3-t4, at 15 psi... something definately seems wrong
Old Jul 11, 2004 | 03:53 PM
h22 civic's Avatar
Default Re: SC61 trap speeds and psi level..?? DISSAPOINTED...!! (R THIS)
what psi spring is in your blow off valve?
Old Jul 11, 2004 | 07:11 PM
CentralFloridaTurbo's Avatar
I went 12.2 @ 122mph / 17psi, in BF's drag radials 205/50/15.
My set up is:
B18 standard bore (9:5:1),eagle rods, ARP head studs,Cometic head gasket, stock head, block guard, SC61 w/inlinepro manifold,Turbosmart wastegate, JG intake manifold, Precision Intercooler & LT-8 MicroTech Engine Managment...
92HB_HB
Jul 1, 2004 10:11 PM
92HB_HB
Jun 27, 2004 11:22 AM
mrod006
May 1, 2003 12:40 PM
Black DC2
Nov 27, 2002 08:27 PM
