purge control solenoid?
Old Jul 8, 2004 | 03:24 PM
Race Egr's Avatar
Default purge control solenoid?
ok i just got a skunk2 manifold and i was putting it on today and it dosent have the little place in the corner to mount it and i know jdm engines dont have it. I was just wondering if I could disconnect it and not run it? Would that hurt performance or cause a cel just wondering thanks
Old Jul 8, 2004 | 03:44 PM
hatchi's Avatar
Default Re: purge control solenoid? (NAPIER)
your idling might fluctuate if you dont have it there or will throw a code. you can just zip tie it
Old Jul 8, 2004 | 04:11 PM
dantastic's Avatar
i would just buy a longer length of vaccum hose and zip the the solenoid to the brake booster vaccum line or something. you could run w/o the entire charcoal canister setup by just simply capping off the connections on the tb and i/m
Old Jul 8, 2004 | 04:25 PM
Race Egr's Avatar
Default Re: (dantastic)
yeah, but would that hurt performance or cause my engine to run rich/lean?
Old Jul 8, 2004 | 05:05 PM
moto27cm's Avatar
Default Re: (NAPIER)
You can just not run it. It will be fine, unless you need to pass a visual test.
Old Jul 8, 2004 | 05:07 PM
suspendedHatch's Avatar
Default Re: (moto27cm)
You'll fail smog and it will hurt your gas mileage. It's so easy to do, just do it right don't pollute the air.
Old Aug 14, 2004 | 10:22 PM
vtec49417's Avatar
ok guys bear with me im new at this, But i have a 95 civic 1.6L sohc vtec according to the Hayes manual what they called the purge control solenoid was located by the rear part of the throttle body which is also got a purge control solenoid sensor ??? Honda wants 130-150 dollars for a little sensor held in by a single phillips screw and is the size of a quarter. Anyone know where i can get that sensor for cheaper than that ??
Thanx
Newbie
mchef117
Jun 20, 2015 08:57 PM
coronadrinker
Dec 7, 2006 08:17 AM
livinlow
Feb 5, 2006 11:48 AM
Hybrid 350GT
Sep 9, 2003 10:42 AM
1 2 NV
Feb 5, 2003 07:27 PM
