warboro 255 fuel pump
guys with high HP are you guys running a Warboro 255 fuel pump?
you think it would handle about 300+ hp daily and 500+ at the track with SS fuel lines?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uglyasscivic »</TD></TR><TR><TD CLASS="quote"> Just recently.... 689 hp at 24psi with Walbro 255 HP. Part # GSS 351.
Make sure you run over a 1/4 tank of fuel if you are at the track.</TD></TR></TABLE>
why is that?
why is that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon_2b_evil »</TD></TR><TR><TD CLASS="quote">
why is that?</TD></TR></TABLE>
so you dont starve for fuel, lean out, and KABOOM...
i've tested walbro 255's and 255 high pressures (the high pressure is mostly hype, practically same ****) on RC engineerings fuel pump dyno, and at .5 BSFC, they are good to at least 740 bhp. and .5 is pretty rich for these vtec engines
How come I ran a walbro in my old civic and it sounded fine, but in my teg the walbro sounds like crap when you turn the key to on position??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 »</TD></TR><TR><TD CLASS="quote">How come I ran a walbro in my old civic and it sounded fine, but in my teg the walbro sounds like crap when you turn the key to on position??</TD></TR></TABLE>
not sure, is it the same exact pump from the civic?
might be going out..send it to rc engineering for testing, or i can get it done there for cheap. email if you need it. steve@tech43.com
yeha thanks.
I was trying to decide because I also have aeromotive A1000 fuel pump and im trying to decide which one im going to run.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. »</TD></TR><TR><TD CLASS="quote">the aeromotive is overkill..noisy..a bitch to install, etc etc. if you are worried, just get a new walbro, they are cheap. good luck.
yeha i know thats why i asked if it would be ok for my setup.
Terry made over 600whp on his walbro 255 on stock lines.
i havent put the power to mine yet, but its like 3.5 years old and holds up great.
and very good idea not to run it lower than 1/4 tank on it, will stress the pump too much
