Stock fuel pump - what hp can it handle?
Ive got a 88' Si doch crx, I am currently running a low 4.7psi with 390cc injectors on a IHI vf10 turbo, I have a walbro 255 fuel pump but havent installed it yet, and am obviously running the stock fuel pump,
So my question is - how much hp/psi can a stock fuel pump handle?
thanks in advance.
thanks in advance.
Re: Stock fuel pump - what hp can it handle? (Outkast95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkast95LS »</TD></TR><TR><TD CLASS="quote">If u have the walboro fuel pump, why not just install it. It takes like less than 30 minutes to do. </TD></TR></TABLE>
I think if its like a DA, you have to drop the gas tank
Mr. Badwrench
Re: Stock fuel pump - what hp can it handle? (jDMJeRk)
i dont trust dx pumps on na setups, and unfotrunately being an ef the tank needs to come out. yuck it up and put in the walbro. it isnt worth the headaches associated with a lean condition.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk »</TD></TR><TR><TD CLASS="quote">
I think if its like a DA, you have to drop the gas tank</TD></TR></TABLE>
Yeah I do, I will install the walbro fuel pump, I did a read up on how to install one but at the moment I dont have the time as I am busy with other things like getting certification for the turbo set up etc,
I havent had time to put a air/fuel ratio gauge in yet and I was just worried that with the stock fuel pump it may be leaning out etc, I dont think so as its not a very big turbo ''a little smaller then a t25'' and I am only running 4.7psi ''at the moment'', currently it is chip tuned and seems to be quite good, but I also have an apexi s-afc ready to go in,
I just wanted to know what a stock pump can handle in hp? just for peace of mind that it isnt leaning out while I am driving ''not thrashing it'' to and from a few places before the walbro goes in
thanks.
Modified by NewZealandJDM at 9:37 PM 7/6/2006
thanks.
Who is Mr Robot?
Re: Stock fuel pump - what hp can it handle? (NewZealandJDM)
i wouldnt risk it with a stock pump.
if you get an a/f gauge make sure its a wideband, those autometers are just a gay light show
you have a chipped ecu... no need for the s-afc
Who is Mr Robot?
Re: Stock fuel pump - what hp can it handle? (playahwitgame)
which isnt really bad. higher fp = less injector duration, better fuel atomization.
id get an adjustable fpr just incase
Re: (ella94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ella94 »</TD></TR><TR><TD CLASS="quote">that pump was made for a 160 flywheel engine. not for a boosted engine making over 200 flywheel. ditch the pump asap.</TD></TR></TABLE>
http://www.prostreetonline.com...pumps/
''These 255 liter-per-hour fuel pumps are conservatively capable of supporting over 640 HP in naturally aspirated motors, and over 530 HP in forced-induction applications.''
Re: Stock fuel pump - what hp can it handle? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">
id get an adjustable fpr just incase</TD></TR></TABLE>
Yeah I was thinking I might need to get one, thanks for the tip
Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">he was talking about the stock pump</TD></TR></TABLE>
oh, for me.
oh, for me.
Re: (NewZealandJDM)
get an adjustable fpr. when i first got my fpr, i bumped it up like 3-4 psi. i got a cel with code p0132 which is oxygen sensor high voltage aka richhhhhhh. get the fpr then put the pump in, if you dont you will be wastin gas
Re: (playahwitgame)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playahwitgame »</TD></TR><TR><TD CLASS="quote">get an adjustable fpr. when i first got my fpr, i bumped it up like 3-4 psi. i got a cel with code p0132 which is oxygen sensor high voltage aka richhhhhhh. get the fpr then put the pump in, if you dont you will be wastin gas</TD></TR></TABLE>
So I assume if I put my s-afc in I couldnt turn the fuel down a little?
althougth I am getting the fpr now
Re: (wantboost)
im not sure about the afc, but then ude be adjusting pulse width rather then pressure. i don tknow man, but for me, i personally would rather mess with something mechanical rather then electronic
Re: (playahwitgame)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playahwitgame »</TD></TR><TR><TD CLASS="quote"> i personally would rather mess with something mechanical rather then electronic</TD></TR></TABLE>
Yeah you got a point
Anyway until I put the walbro in I assume it would be ok to drive my crx gently eg changing gear before boost comes in and accelerating very gently?
Re: (NewZealandJDM)
hey Im going to try and install a walbro 255 fuel pump, ive found a write up about it so thats all good, but I am a bit unsure about taking the fuel tank off, anyone know of any write ups about it?
Ive found the bolts to take it off but I dont know what fuel lines to disconnet?
any help will be really appreciated!
thanks
thanks
my best friend has made over 300whp on a stock 92-95 DX fuel pump. on 2 different setups with no problems
so if anything you could always just get a gsr/si/itr fuel pump.
trooper0641
23
04-06-2005 12:51 PM
