Ecu chipping
I want to chip my p28 myself...
Well what i am asking is what is the minimum watts for a soldering iron...
will i be able to solder a chip with a 25watts iron? or should i need a 60watts...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyzee »</TD></TR><TR><TD CLASS="quote">I used a cheap 3$ iron from the local dollar store and it worked fine. I've done 15+ ecus with it with no problems at all.
Hope that helps somewhat</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punku10 »</TD></TR><TR><TD CLASS="quote">any cheap soldering gun will work fine for an ECU its when you start to solder big heavy wires and such that you will need a bigger better gun </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hatch »</TD></TR><TR><TD CLASS="quote">all it needs to do is heat up enough to melt solder, if your not sure try it on an old video carld or something.</TD></TR></TABLE>
Cool! thank you for the help guys
