Question about putting in gauges...
Old Jul 7, 2004 | 09:48 PM
liljohnson's Avatar
Default Question about putting in gauges...
I installed some indiglo gauges the other day on my car and the gas and water temp. gauges aren't working because the hole around where the needle's base is stopping their rotation. At least that's what I think. Do you pull out the stock faces first and then set the new ones down or do you just put them over the original ones? Can ya'll help me out?
Old Jul 7, 2004 | 10:27 PM
liljohnson's Avatar
Default Re: Question about putting in gauges... (liljohnson)
Bump.
Old Jul 7, 2004 | 10:29 PM
=GAME='s Avatar
unscrew those little philip screws and lay them over your stock gauge then put those screws back on.
Old Jul 7, 2004 | 10:33 PM
liljohnson's Avatar
Default Re: Question about putting in gauges... (=GAMEOVER=)
That's what I did but for some strange reason they still won't turn.
Old Jul 8, 2004 | 06:22 AM
liljohnson's Avatar
Bump.
Old Jul 8, 2004 | 06:24 AM
Sijray21's Avatar
what car is this in?
Old Jul 8, 2004 | 07:16 AM
liljohnson's Avatar
Oh, sorry... A 1992 Honda Civic DX.
Old Jul 8, 2004 | 07:19 AM
Sijray21's Avatar
no worries.
the holes in the guages are big enough for the base of the needle right?
you didn't remove the needles when you installed the guages did you?
i know before when i had some in my car that if you removed the needles then you broke the guages.
Old Jul 8, 2004 | 07:29 AM
punku10's Avatar
Default Re: Question about putting in gauges... (Sijray21)
1. take out those little pain in the dick screws.
2. its weird but bend and slide the indiglos over the needles without taking the needles off
3. put the screws back in
4. wire it up. i'd explain more but it doesn't sound like you have a problem with this yet
Old Jul 9, 2004 | 06:36 AM
liljohnson's Avatar
Default Re: Question about putting in gauges... (punku10)
I did all that but it seems like the holes on the new gaugues aren't big enough for the base of the needle to rotate.
nocturnaldragon
23
May 3, 2004 03:01 PM
matt7137
Jul 11, 2003 08:13 AM
MidwestSi
Jan 20, 2003 09:24 AM
snake01
Mar 20, 2002 10:31 PM
