Upper control arms
Old Jul 7, 2004 | 09:34 PM
Magick211's Avatar
Default Upper control arms
I recently bought a 92 si hatch, i got to looking at both upper controls arms while the car is sitting and the passanger side is lower?(the control arm that is) the car sits level. nothing seems to be bent but i do know the hub assembly was replaced a while back. Could taht be why its lower on that side if its an aftermarket hub assembly are something? not saying it is an aftermarket one cause im not sure.
Old Jul 7, 2004 | 10:30 PM
Magick211's Avatar
Default Re: Upper control arms (CivicBoyZC)
Anyone?
Old Jul 7, 2004 | 11:26 PM
hatchi's Avatar
could it be a shock is blown, making that side sag a bit. or check the springs if they are on the same way
Old Jul 8, 2004 | 12:37 AM
Magick211's Avatar
Default Re: Upper control arms (hatchi)
no the car sits level. its just one of the upper control arms sits higher
Old Jul 8, 2004 | 01:03 PM
Magick211's Avatar
Anyone else?
Old Jul 8, 2004 | 06:30 PM
Magick211's Avatar
Oh well the car sits level and everything looks straight so im not gonna worry about anything
Old Jul 8, 2004 | 11:24 PM
brizdo's Avatar
make sure the springs are adjusted properly if theyre adjustables.....haha im sure you wouldnt forget that anyways tho
Old Jul 9, 2004 | 12:17 AM
Magick211's Avatar
Default Re: Upper control arms (brizdo)
Yeah they are non ajustable springs. and like i said the cars sits straight from what i can tell
Old Jul 14, 2004 | 10:16 AM
EK k kay's Avatar
I sort of have the same problem except on my driver side the upper control arm is angled upward a little bit and the front driver side sits about 0.5in lower than the rest of the corners. What could be the problem?
Old Jul 14, 2004 | 01:17 PM
Magick211's Avatar
Default Re: Upper control arms (chowmien)
Yeah man thats my problem too
Old Jul 16, 2004 | 01:31 PM
EK k kay's Avatar
Here are some pictures. You can see the wierd angle of the driver side front upper control arm. It's pointed higher and is much closer to that part of the fender housing. Any input is appreciated. Thanks
Driver Side
Passenger Side
Old Jul 16, 2004 | 01:32 PM
Magick211's Avatar
Thats excatly how mine is , thaks for posting the pics and giving people a better idea
Old Jul 16, 2004 | 01:49 PM
EK k kay's Avatar
I might go have it checked out this weekend. I'll post results if I do go.
Old Jul 22, 2004 | 12:33 AM
EK k kay's Avatar
It was the obvious: the spring was going. Gives me a reason to get some lowering springs
Old Jul 22, 2004 | 08:10 AM
jspresso's Avatar
hhah every honda that ive had (3) has had over 130k on it and they have all sat lower on one side, ***** fucked
1993_EJ1
Jan 5, 2011 11:51 PM
bcrosby51
Jul 24, 2007 11:42 AM
skyliner186
11
Dec 29, 2003 08:39 PM
