fire under the dash.
Alrighty, im under the hood, while white smokes pouring out of the doors, pull the terminal off the battery, it stops, Pull the dash in 37 minutes flat
and find that 3 black wires with silver rings, run into 1 wire of the same gauge and color and run down to the ground on the radio harness plug. Im guessing all grounds? anyone have a clue why the hell it would just burn the **** out of them all the sudden?
thanks
pat
and find that 3 black wires with silver rings, run into 1 wire of the same gauge and color and run down to the ground on the radio harness plug. Im guessing all grounds? anyone have a clue why the hell it would just burn the **** out of them all the sudden?thanks
pat
same **** happend to me! except my car didnt burn up. Me and my friend installed my radio. everything looked good except for this window washer LEDs that the privious owner had instaled inside. i didnt want to mess with them cause i couldnt understand how the hell he hooked them up, so i left them alone. i started the car and behind my radio i saw a little glow then smoke started to poor out, the dam LEDs shorted the system or something.
