Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
SRR LCA's
Old Jul 7, 2004 | 03:02 PM
toadolson's Avatar
Default SRR LCA's
Did a search but did not find the answer I'm need.
About to pull off my neuspeed lower tie bar and but on a comptech tie bar/sway bar kit with SRR lca's on the car. This is on a 94 civic coupe dx. The ? i have is about the u-shaped brace from comptech and how it bolts to the lca. I know i need to buy a bolt to mount this, but I'm worried about the larger contact patch of the u-brace compared to a bolt on the other side. Was planning on doing a washer about the same size as the contact patch as the u-brace to = the stress or am i doing this for as overkill. Any problems with the bolt plate on the lca cracking out.
Any input would greatly be appreciated
Thanks Todd
Old Jul 7, 2004 | 03:09 PM
JeffS's Avatar
Default Re: SRR LCA's (toadolson)
What are you asking?
The comptech bar comes with bolts, and instructions for installation - which are also posted on their site - http://www.comptechusa.com/instructions/ins078.pdf. The fact that you have SRR lca's is irrelevent. The subframe brace doesn't mount to the lca, it mounts to the subframe, and through the lca.
Old Jul 7, 2004 | 03:16 PM
toadolson's Avatar
Default Re: SRR LCA's (JeffS)
Sorry, must have worded it wrong. Where the sway bar ties to the lca. I've hear of it called a helms joint. This is where the sway bar bolts to the lca with a u-shaped brace. On one side of the lca it has the brace and on the other is only has a the bolt. The surface area from one side is larger than the other. I'll try to find the photo some where in here.
Old Jul 7, 2004 | 03:24 PM
RineRacing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toadolson &raquo;</TD></TR><TR><TD CLASS="quote">Was planning on doing a washer about the same size as the contact patch as the u-brace to = the stress or am i doing this for as overkill.</TD></TR></TABLE>
Why not? Even if you don't need it, it will at least get rid of the worry in the back of your head.
I guess the only draw back is that it will make you $.50 poorer.
Old Jul 7, 2004 | 03:32 PM
toadolson's Avatar
Default Re: SRR LCA's (Geratol)
Just looking at this 22mm bar and figuring a steel plate on one side of the lca and on the other, a NUT. With a piece of aluminum between them looks to me like a stress fracture waiting to happen. Have not gotten the lca's in yet, but did not know what situation had taken place.
Old Jul 7, 2004 | 03:44 PM
JeffS's Avatar
Ok... that makes sense.
I've always wondered about the swaybar mount on those arms... it does seem like a potential weak-point, but then again, I've never heard of one failing.
itslogz
Suspension & Brakes
Sep 29, 2009 08:02 PM
wlee112
Jul 12, 2007 08:13 AM
Linh.
Apr 18, 2006 12:45 AM
XLR8 GS-R
Jun 11, 2004 04:35 PM
ef ect
Oct 7, 2003 07:59 PM
