GSR SEATS FABRICATIONS
It's not a popular swap because when you put the new seat it, you have to cut into the rear headlight blinker fluid line. You have to relocate the firewall strain relief to the trunk and then weld or bolt in a bracket in to hold up the main relay connector bearing. That's all easy work and should only cost you about $5 and about 9 hours of labor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">It's not a popular swap because when you put the new seat it, you have to cut into the rear headlight blinker fluid line. You have to relocate the firewall strain relief to the trunk and then weld or bolt in a bracket in to hold up the main relay connector bearing. That's all easy work and should only cost you about $5 and about 9 hours of labor. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDABOI505 »</TD></TR><TR><TD CLASS="quote">i just wanna put the seat in how can i fabricate everything to fit</TD></TR></TABLE>
lmao.....my day just got a little better.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art In Motion »</TD></TR><TR><TD CLASS="quote">ok i admit i laughed but thats fucked up guys
theyre just ****** with you man the seat will bolt right up
they will not bolt right up... check out my writeup in this thread. if you swap the rails then yes they will bolt right up, but if you use the grs rails, they will need to be slightly modified.
https://honda-tech.com/zerothread?id=846588
</TD></TR></TABLE>they will not bolt right up... check out my writeup in this thread. if you swap the rails then yes they will bolt right up, but if you use the grs rails, they will need to be slightly modified.
