intake manifold suggestions please!!!
Old Nov 20, 2001 | 04:05 PM
tommybanzai's Avatar
New User
Default intake manifold suggestions please!!!
Hey everybody. My friend has been looking into getting his hands on an intake manifold, and both of us have heard little about the ones that are out (that we know of): HP, STR, skunk2, JG Edelbrock,.... let me give a lil info about his car: 1998 GSR, Fmax turbo kit, 8 or 12 psi, Tanabe racing medallion catback, MSD 6AL with timing retard inside, STR fuel rail....and a bunch of other bolt on BS....
Questions:
1) Intake manifold suggestions based on hear-say or personal use?
2) Intake manifold use for his car (show piece or active peice)?
Thanks, Tom
Old Nov 20, 2001 | 08:01 PM
D-Man's Avatar
Default Re: intake manifold suggestions please!!! (tommybanzai)
id get the JG/Edelbrock Victor X cause it makes more power than either the Skunk 2 or ITR and it has a mounting pad for the stock Idle Control Motor..which the STR,VENOM,HP and Matrix Dont...these manifolds are better suited for a stand alone ECU like a SPEEDPRO or Accel Dfi...if you went stand alone..id get the STR.
Old Nov 20, 2001 | 09:01 PM
BoM's Avatar
BoM
Default Re: intake manifold suggestions please!!! (D-Man)
how do u know that....its an advertisement...depends on your engine man
if ur gonna be above 9k then it would be a good investment for the x, but that thing hasn't been publicly tested yet.
and for ur friends application, the skunk2 manifold polished would be nice
gsr dual runners aren't that good when its modded alot. Madd poWeR u bE geTin with it fo shure...
and since he wants show polish always looks nice...especially if it matches your polished wastegate
[Modified by BoM, 1:02 AM 11/21/2001]
Old Nov 20, 2001 | 09:09 PM
VaporTrail's Avatar
New User
Skunk2 is perfect for mild to moderate street f/i setups. onefastb18c made 617 to the wheels still using an unmolested Skunk2 on a GSR head. So it flows plenty I think
Old Nov 20, 2001 | 09:43 PM
b18bvudoo's Avatar
New User
Default Re: intake manifold suggestions please!!! (VaporTrail)
did i just read that right...617?!?!?!
Old Nov 20, 2001 | 09:53 PM
VaporTrail's Avatar
New User
Default Re: intake manifold suggestions please!!! (vudoo666)
well yeah, it's a full on race car, 10.60@138mph and no friggin traction on 24x8x13's without wheelie bars
Old Nov 20, 2001 | 10:27 PM
98hx99b18c's Avatar
Default Re: intake manifold suggestions please!!! (BoM)
didnt Jojo Callos make like 20 or 40 more hp with the victor X or pick up some top speed with it. Anyone else using this, any thoughts?
Old Nov 20, 2001 | 10:43 PM
Turbo EG6's Avatar
New User
Default Re: intake manifold suggestions please!!! (98hx99b18c)
Is this the manifold you are talking about?
[Modified by Turbo EG6, 7:43 AM 11/21/2001]
Old Nov 20, 2001 | 11:11 PM
VaporTrail's Avatar
New User
Default Re: intake manifold suggestions please!!! (Turbo EG6)
wow those is some short runners!
Old Nov 21, 2001 | 04:49 AM
GSRacer's Avatar
New User
how much does the JG run for?
Old Nov 21, 2001 | 05:45 AM
TurBoTeG's Avatar
Default Re: intake manifold suggestions please!!! (GSRacer)
Anyone know anything about the Venom intake manifold??
Old Nov 21, 2001 | 05:50 AM
Smashback's Avatar
Default Re: intake manifold suggestions please!!! (TurBoTeG)
Yes, I've been wondering how well the Venom and Focuz manifolds work. Anybody use them?
Old Nov 21, 2001 | 08:01 AM
Turbo EG6's Avatar
New User
Default Re: intake manifold suggestions please!!! (mplex2000)
The JG manifolds are retailing for around $420 or so I believe. I have one on the way, I wonder what will make more hp and tq, my HP Racing sheet metal or the JG.
Old Nov 21, 2001 | 08:25 AM
TurboT's Avatar
where did you order the JG from?
did you get the 4 injector version or the 8?
Old Nov 21, 2001 | 08:58 AM
Turbo EG6's Avatar
New User
Default Re: intake manifold suggestions please!!! (TurboT)
Directly from JG. I believe it is the 4 injector version. When I spoke to Jaiver he said he has gotten the last 45 pieces, and that there will not be another run of them until sometime in Feb.
[Modified by Turbo EG6, 6:43 AM 11/22/2001]
Old Nov 21, 2001 | 09:10 AM
TurboT's Avatar
what's javier's number?
Old Nov 21, 2001 | 09:13 AM
TurboT's Avatar
i need the 8 injector version...
can you get that?
Old Nov 21, 2001 | 09:14 AM
DirtyLude's Avatar
What motors did they produce them for. Let me guess. No H22a.
I'd definitely be interested in an H22a app.
Old Nov 21, 2001 | 09:41 AM
Turbo EG6's Avatar
New User
Default Re: intake manifold suggestions please!!! (DirtyLude)
Ok spoke to Javier again, all of the manifolds come with injector bosses on the bottom on the manifold (see pic below). You have to it drilled out yourself. Javier also said they picked up 20hp at 12lbs. over the STR manifold. JG only has like 40 or so left, and they will be selling them for $420, I will be selling them $395+shipping. I believe currently they are only making them for the B18C.
[Modified by Turbo EG6, 6:44 AM 11/22/2001]
Old Nov 21, 2001 | 10:23 AM
TurboT's Avatar
ok, what about the fuel rail?
is there mounting holes for that?
i see what you're talking about the boses..
you just have to drill the pass through hole, then drill a counter bore for the grommet, etc...
from the pic, i'm just worried about how the fuel rail would be mounted...
so, they are not selling an 8 injector manifold already drilled and with a fuel rail?
i thought i saw one from sema
Old Nov 21, 2001 | 10:26 AM
TurboT's Avatar
looking from the pic again..
there doesn't seem to be enough material for the injectors...
do you have to weld on an injector boss?
lemme see if i can find a pic of the manifold that i'm talking about.
http://www.overboost.com/pix.asp?ima...l/DSCN1401.jpg
doh, nevermind... i see it now..
can i purchase a manifold from ya?
what about that fuel rail?
do they sell that?
[Modified by TurboT, 11:28 AM 11/21/2001]
[Modified by TurboT, 11:37 AM 11/21/2001]
Old Nov 21, 2001 | 10:39 AM
Turbo EG6's Avatar
New User
Yes you can, let me know if you want one for sure, so I can have him add me another one to my order. I believe they sell the rail seperatly. I will check on that, probably won't be till monday when I find out. They were really busy today, and I think they are closed Thursday and Friday.
Old Nov 21, 2001 | 10:47 AM
TurboT's Avatar
yeah, i want one....
if you can find out about the rail too...
i'll need that too...
chungt1@aol.com
terry
Old Nov 21, 2001 | 12:31 PM
brian b's Avatar
New User
its amazing how many times i hear from shops that the JG manifold is super bomb, and that the STR sucks.. and for each one of those times i hear the STR manifold is super bomb and the JG sucks. does anybody have true dyno plots from both of these manifolds on the same motor?
Old Nov 21, 2001 | 01:34 PM
BoM's Avatar
BoM
Default Re: intake manifold suggestions please!!! (brian b)
STR sucks!
and JG im still undecided...
but i'd only get it if i had a high *** redline
it says 7k - 10k power band
