Help about 1992 Ex Sedan
Old Jul 6, 2004 | 09:44 PM
bbcnet's Avatar
Default Help about 1992 Ex Sedan
i just wondering is ex is vtec motor or not cause today i saw a 1992 ex sedan that doesn't have vtech on top of the cover . on more question should for a 220000 miles civic ex should i just replace another motor or stay same one ? i just bought for 1200 clean title
Old Jul 6, 2004 | 09:47 PM
hatchi's Avatar
Default Re: Help about 1992 Ex Sedan (bbcnet)
92-93 vtec motors didnt have vtec stamped on valve cover only the 94-95 did
Old Jul 6, 2004 | 09:52 PM
=GAME='s Avatar
Default Re: Help about 1992 Ex Sedan (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">92-93 vtec motors didnt have vtec stamped on valve cover only the 94-95 did</TD></TR></TABLE>
btw: to the starter, i take it you are not from here.
Old Jul 6, 2004 | 09:58 PM
bbcnet's Avatar
so should i replace another motor or just stick with it, this motor has new timing belt and clutch
Old Jul 6, 2004 | 10:49 PM
boostng r's Avatar
a
if it runs good no smoke then keep it but uif u wanan race it and be on a budget get a b16 swap for like 2100
Old Jul 6, 2004 | 11:35 PM
bbcnet's Avatar
Default Re: Help about 1992 Ex Sedan (b16coupe4)
will that is a sedan i don't think will use that to race at all so don't know it has smoke or not but i assume that will pass smog and ok with it
Old Jul 7, 2004 | 08:02 AM
FERIOkid's Avatar
F DOHC i got a SOHC turbo for $1800 ($400-$500 less then your B16) and it will **** on a B16 when i get it running (lets hope)
I say buy a D15B from http://www.hmotorsonline.com and call it a day. ... Then boost it if you want to
Old Jul 7, 2004 | 08:08 AM
Dacalac's Avatar
Default Re: Help about 1992 Ex Sedan (slowdx9585)
I would say do compression and leak down tests on the motor. But if you want to swap on a budget, go with another d16z6. A lot of people are saying go d15b, but I think parts for it would be hard to find. Might as well go with the z6 since it has huge after market support.
As far as boost goes, make sure you do all your research because going with a FI car requires a lot more maintenance.
Old Jul 7, 2004 | 08:35 AM
boostin4drcivic's Avatar
Default Re: Help about 1992 Ex Sedan (Dirk Lance)
it is a vtec motor, look at the stamp on the front of the engine block to the left of the header. it should say d16z6. it just doesnt have it marked on the valve cover.
Old Jul 7, 2004 | 09:56 AM
skunk2eg's Avatar
Default Re: Help about 1992 Ex Sedan (boostin4drcivic)
just like he said^. yeah its sohc vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbcnet &raquo;</TD></TR><TR><TD CLASS="quote">so should i replace another motor or just stick with it, this motor has new timing belt and clutch</TD></TR></TABLE>
if it runs good boost it, i was preparing to do that to mine (before i blew the motor)
but if u swap go b18b despite the way most look at them, they are awsome motors
Dubsackx1
Aug 6, 2008 01:27 PM
clgnv21
Jun 25, 2006 03:08 PM
2ndGenREX
22
Apr 19, 2005 02:42 PM
MyKeerInYourEar
13
Aug 19, 2004 11:12 AM
hcivic99
13
Aug 8, 2004 08:46 PM
