Rear Deck Speakers
i have a 96 civic coupe and i wanted to know whats holding the rear deck speakers, is it just those white plastic things? if so how do i take em off?
If the grills sit on top of the rear deck . there are 3 or 4 10mm bolts going up into grill from trunk , if grill is part of rear deck,you must remove it and there are 4 philips screws holding speaker from the top.
hope this helps. 94
hope this helps. 94
Sorry no, dont have scanner there are a few good pix on some posts try search . 94
ps Is the speaker grill part of the plastic rear deck trim, and flush, or does the speaker grill sit about one inch higher then the rear deck and not part of it . 94
