Gunna install GReddy boost gauge....which way?
I'm gunna install my GReddy boost gauge soon and I have a question. It uses a vac. line T-ed off of something (I'll probably use the fpr), which goes to a boost sensor. Then the sensor has a wire that goes to the control unit for the gauge.
Should I mount the boost sensor under the hood or under the dash. If I mount it under the hood it might get wet, hot, or see interference. If I mount it under the dash the vac. line might get crimped while traveling so far....especially through the firewall.
Which way did you guys do it?
You want it under the hood... such is the purpose of a gauge with an electronic sender.. else you should have just bought a mechanical boost gauge.
Dustin
Dustin
I have mine on the firewall. The screw they provide fits perfectly in one of the holes.. looks almost like it was made to go there
Styler93GSX
Jan 14, 2004 06:22 AM
Flamenco-T
Aug 7, 2001 07:49 PM
