p13 ecu with f22b1?
Old Jul 6, 2004 | 08:24 PM
dav3ddt's Avatar
Default p13 ecu with f22b1?
I don't have an accord ecu and so I tried the p13 ecu I had laying around. I am getting a code 23 for the knock sensor which causes it to run in limp mode. The engine doesn't have a knock sensor for me to hook up either. Anyone know how to bypass this code from the ecu? I do have a knock sensor that I could tap into the block but I rather just get the stock ecu.
Old Jul 6, 2004 | 09:03 PM
Nick H's Avatar
New User
Default Re: p13 ecu with f22b1? (dav3ddt)
the p13 ecu will not work very well with the f22b1 even if you do get the knock sensor hooked up...the fuel and ignition maps are totally different and is designed for a motor revving to 7200 rpm's, not 6200...vtec engages much later than on the stock ecu...if you really want an ecu that has aftermarket support (i.e. hondata etc) then get a p28...the p28 doesn't have a knock sensor and you will run error free...just make sure someone burns a ROM for you with the correct fuel and ignition maps so you don't blow your **** up...
Old Jul 6, 2004 | 10:09 PM
hotrodaccord's Avatar
Default Re: p13 ecu with f22b1? (Nick H)
what car does a p28 ecu come from?
Old Jul 6, 2004 | 10:37 PM
Nick H's Avatar
New User
Default Re: p13 ecu with f22b1? (hotrodaccord)
some sohc civic i believe...
Old Jul 7, 2004 | 06:37 AM
a94si's Avatar
The p28 came from a 92-95 civic ex/si
Scotty B
Mar 26, 2021 03:15 PM
Stray
Jun 19, 2007 02:38 AM
UncivilB18C
Apr 10, 2006 05:21 PM
ninkei
Nov 15, 2005 04:45 PM
Eg6_JDM
Apr 14, 2002 07:47 PM
