Hit bump car shut off
I was driving through town today and went over a sewer cover. After I hit the sewer cover my car shut off/ stalled. As i pulled over i shut off the car and restarted it, it would start then the RPM's would drop and stall the car out again. I repeated this like 4 times. After the 4th time i restarted again and it ran like a champ. This only happened one time before and that was in december.
My question is why would it do this? To stiff of a ride and something just hit to hard and caused the car to shut off? No CEL came up, though I wish maybe it did. Thanks for the help.
Car- 95 civic Ex- I/H/E. - D16z6
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej1_coupe »</TD></TR><TR><TD CLASS="quote">I only have a key and my alarm controller on a key ring.
UP</TD></TR></TABLE>
check your grounds and battery conntection
Had the same **** happen to me. And now (about a month or so later) it shuts off whenever it wants and im starting to throw a code 15 (ignition). Somehow when i bottomed out on a curve in the road (not a dip you know when the road on the freeway goes down then up) it fucked up my ignition now the car wont start. Next time the car dies look to see if your throwing a code. Good luck.
Thanks. Ill check all my wires and grounds tomorrow. Hopefully it was just a fluke agian. Its been about 7 months since its done this and after that point had been running strong. Good luck to you too Luser. Thanks.
hondastrtracr
Mar 10, 2007 04:55 AM
sleepin91teg
14
Jul 5, 2004 09:48 AM
